The oil pump is adjustable ( 3 positions ) the adjuster screw is located under the crankcase below the sprocket, there is also a filter in the oil tank, you will need to gently lever out the oil pick up pipe from the oiltank, it has a grommet in the centre to keep it tight in the tank, failing that there is a nylon gear driven via the drive sprocket, this may have become damaged.
