SOURCE: I have a 17kw generac generator that will run
I have the 18KW model and was told that most alarms relate to a low battery. Make sure the battery charger in the Transfer Switch is properly feeding the battery or hook up a mobil battery charger to the battery and see if the alarm goes away. Good Luck.
SOURCE: Kohler Model 12RES LP gas generator starts
Sounds like a short in one of the windings to me. Can you verify that the engine rpm is not exceeding specs? If you can modify the engine speed Id say slow it down and see what the voltage read is.
SOURCE: Can some one tell me what oil and air filter to
Lowes sells air filters for Kohler engines . As far as the oil a SEA 30 or 10w 30 would be fine.
