Computers & Internet Logo
Tex Smith Posted on Oct 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a dlink DIR-615 attached remotely to another home router system. It is hardwired via a LAN port and I connect to internet via the remote DLINK router via wire or wireless just fine. Problem is I can't access the DLINK router programing. I have reset it a few times and reprogrammed but once I exit I cannot access the IP address I gave it when programming. Windows shows no website found
Anonymous
Level 3:
  • Master 1,940 Answers
  • Posted on Oct 28, 2011
Anonymous
Master
Level 3:
Answers
1940
Questions
0
Helped
954182
Points
5951
After you change the IP address of your Router, you have to reset your Network Card IP address if it is Dynamic. If your IP address is Static you need to manually make these changes from within Windows. Else, reset your computer and try accessing the newly issued IP address for your Router.
Close all Browser Windows and Programs before continuing.
From the Command Prompt, type:
C:\> ipconfig /release
Press Enter, and then type:
C:\> ipconfig /renew
Now try and access the New Router IP.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
2answers
My Dir 615 router always looses internet connection to my wired computer
Try to upgrade the routers firmware.
http://www.dlink.com/us/en/support/product/dir-615-wireless-n-300-router
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
How to connect TP LINK TL-WA901ND with Dlink DIR 615
Have you set the TP Link TL-WA901ND IP to have 192.168.1.1 as the default gateway ?
Also DHCP server is where ?
IN the TP LINK TL-WA901ND or in DLINK DIR 615
Only have one Router running DHCP and set the default gateway in the leases as 192.168.1.1.
What subnet mask are you using is it the same through out all devices ?
How do I connect a Dlink wireless router to a Netgear WiFi Internet adaptor?
Hi there is two way to connect best is to connect via cable ,DIR 615 login to router setting by typing 192.168.0.1 enter user name and password uaser name will be admin and password could be admin or blank or you need to enter text " read the manual to access the router via internet explorer" make sure WAN connection is DHCP connect LAN cable from your main router to the WAN port of your Dlink it should be ready in 1 miutes also if it support WDS you do not cable it can find the main router signal and connect to it and boost it , should you need any help please post me your question to http://computernetworksupportindubai.com/
1helpful
I have followed instructions (several times) to connect my dlink router dir-615 and once I unplug the ethernet cable and attach to dlink (blue slot 1) and plug in power to the router....it no longer can...
the blue socket should be connected to your modem, it is this modem that supplies the internet for your router to distribute to your computers so if you disconnect the blue cable from your router you are disconnecting the internet
1helpful
2answers
Dlink DIR 615, network name changed, won't accept password
It appears your brother has changed your wireless router settings.
You can reset the Dlink back to the default settings by -
Power off the Dlink and press and hold the RESET button on the back of the Dlink and the power on the Dlink. Hold the RESET button for 5 secs. until the LEDs flash at the same time.
Connect a LAN cable from the computer to the Dlink. Open a browser and enter the Dlink's configuration URL
http://192.168.0.1
Default login = admin
PW = blank (just press Enter)
You can now change the admin password and set up a new passphrase (ie encryption)
For details on how to secure your wireless from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
3answers
Wifi problem of DIR-300 dlink
just open the dlink ip homepage and configure the wireless settings
sagar
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
