Question about HP LaserJet 2840 All-In-One Printer
Hp colour laserjet 2820 keeps coming up with error 5. i've turned off and then on but keeps coming up with the same error. is it the bulb?
  • HP Master
  • 1,121 Answers
Step1: Open flat bed galss & optical scanner assm, clean flat bed glass, as well as clean internal reflecting glasses in optical scanner, ensure that don't use any kind of cleaners to clean the reflecting glasses, use ear buds to clean gently..Step 2: Replace optical scanner assembly..
Posted on Oct 25, 2011
SOURCE:
2820 error 2
Kevin_Trenow is correct with his solution to the HP colour Laserjet 2820 error code 5 problem - Thank you.
The symptoms are that the machine turns on but after initial movement of the lighted up scanner, there is a disturbing ratcheting noise as if the scanner is trying to move but can't. The machine comes up with error 5 and suggests turning off and on again - this is a waste of time.
1. The top document feeder is released by detaching the multiplug and simply (carefully) removing the whole section.
2. This allows the removal of 8(?) screws from the second layer which contains the glass platform. The screw heads were removed using a star drive, labelled CR-V T10. (Buy Draper 31 piece Precision Screwdriver and Bit set; part no. PSS31)
3. Carefully lever off the grey surround with button labels on it - probably between 6 and 8 clips attach it.
4. Now lift/gently lever off the glass containing layer.
5. Use a spectacle wipe or erquivalent to wipe the glass over the white strip (This is the problem - the scanner light needs feedback from the white strip to end up in the correct position - the 'ratcheting noise is caused as the stepper motor continually moves the head to find the feedback point)
NB. The glass above the white strip will look perfectly clean - looks can deceive!
6. Replace the glass containing layer, ensuring it is clipped in - don't screw up yet in case more cleaning is required
7. Turn on and the scanner light should end up in the required position.
8. Replace screws, replace lid, push on grey panel and you should have a fully working machine for the price of a spectacle wipe.
Mar 13, 2012 | HP LaserJet 2820 Printer
Supply error 10.1004 on HP laserjet 2820 printer
this error comes when the printer not reco the cairtages & drum if u replaced the print cairtages then replace the drum & calibrate the printer & restore the factory default.
May 12, 2010 | HP LaserJet 2820 Printer
Prints smudges in many colours
the most common causes for multi-colour smudges and streaks are the laser-module (or scanner) and/or the photoconductor unit (also called drum).
Apr 20, 2010 | HP LaserJet 2820 Printer
Hp color laserjet 2840 locks up at startup
Remove all toner carts
remove network card
remove memory
Turn off
Turn on...wait for error messages to stop.
Turn off
Reinstall items
Turn on
Jan 30, 2009 | HP LaserJet 2820 Printer
HP Printer Color LaserJet 2840 Printer makes clicking noise and shows on display: Scanner bulb warming up - scanner error 5 Turn off then on but this does not work. Is it mechanical problem or software...
I Have A HP Laserjet 2820 on power up went through to scanner bulb warming up then made a clicking noise comming from scanner unit it was trying to escape the case. if this is the same as yours the problem is that the scanner unit can't find the home position strip mounted betweent the gray case wide piece right hand side as you look down on scanner unit with lid up & the top of the scanner glass inside the scanner unit to get to it you must remove top section of the scanner unit & cleean underside of scanner glass please E-mail me if you want full instruction.
Oct 13, 2008 | HP LaserJet 2820 Printer
Clear error code on hp 2820
Could be scanner assembly or formatter
Jun 24, 2008 | HP Color LaserJet 2600n Printer
HP Laserjet 2820 getting error 10.1004 supply error when installing a new imaging drum. Anyone ever got this error msg? Thanks
Does it work with this error....if so you wanna
make sure that you have a HP cartridge, sometime the chipset is not recongnize....and you have some function that doesn't work. If you try all this, call HP.
Mar 26, 2008 | HP LaserJet 2820 Printer
HP Color LaserJet 2820
The flat bed scanner assy is bad and needs to be replaced. The part number is Q3948-60191. Hp recomends taking it to a repair center for replacement
Jan 13, 2008 | Office Equipment & Supplies
HP LaserJet 2840 All-In-One Printer Logo
155 people viewed this question
Clive
Clive
Thomas F. Schneider
