Xtatix XCA-PP2A Webcam Logo
A
Anonymous Posted on Oct 24, 2011
It want let me install in my computer - Xtatix XCA-PP2A Webcam
Install cd says I need flashplayer. I have it installed in my computer
if that cd have installation setup and ask to install,let it..or upgrade ur player
MP Navigator EX not installed
There are two possibilities. Maybe drivers does not support the operating system, or maybe the wrong drivers installed.
Solutions for possibilities drivers do not support OS
1. Download drivers from Canon Support & Download
2. Select Product category = Multifunctional Inkjet Printers
3. Product series = Pixma
4. Model = Pixma MP258
5. Document type = Drivers & Softwares, then click Find
6. Select OS = Example; Linux
How to install the the printer driver
Install the printer driver, then connect the USB to the computer. If the USB cable is plugged into the computer, then install the new driver, happens is the failure of drivers install process.
Solution to fix the drivers install error
1. Unplug the USB cable from the printer, to the computer.
2. Uninstall all software and drivers are already installed, then restart the computer.
3. Insert the Driver CD, do the install process. About a 90% of the install process, it would come the request "connect the printer to the computer".
4. Connect the USB cable, with a computer.
5. The computer will detect the printer, and install process will continue until completed. After the install is complete, the printer is ready to use.
Hope it helps
PLS NEED INSTALL
Important Notes
Computer softwares are the programs that would be integrated ino the computer by a process called installation. Available installation softwares include productivity, multimedia, creativitiy and gaming programs. Computers already have programs installed to perform also known as operating systems softwares. When a computer is turned on, the display systems making possible user experince is the defaul programs. Every additional features is capable of being intergreted in processes discribed. A required program whether in video editing is chosen after observing the already existing programs on the computer. The decsion to integrate an additional software is with consideration of an entire computer compartibilily check.
Computer situations requiring installation
1. The computer default programs are malfunct
a. outdated computer programs request integration improved features to function
b. a damage to the computer default programs requires repairs by installing.
2. The option to integrate a program to a computer device
a. several programs are capable of being integrated
Procedures of -installing softwares
component check requirements check
1. computer compartibility to software programs selections required to be installed
a. A computer capacity to hold additional softwares
b. a computer functionalities, productivity, video multimedia creation, computer gaming
c. the programs functions could determine if additonal component parts have to be acquired to complete the integration experiece
contact technical support
How we can install hp o/s to hprp2470 model server
if your using a HP computer than you wont be able to install the OS installed on your computer.. HP has a feature that protects the OS being installed on any other computer.. in a way it creates an Image of all the Hardware Devices installed on ur computer thereby restricting u to install it on any other computer.. let me know if i was able to answer ur question or u need some other details.. regards, guru :-p
Can not read disk error
You can't install any hard disk from any computer and install it into your computer and expect it to work unless it came from the same model computer with the same devices that are installed on your computer.
When Windows is installed it configures the operating system unique to that computer and stores this info in the Windows registry.
To get a used hard disk to work in your computer, you have to install Windows as a fresh installation on your computer.
2answers
Drive tools software
driver detective
i have used it on multiple pc's
please don't forget to rate
Driver will not install on Windows XP
BETTER TO UNINSTALL FIRST THE PREVIOUS DRIVER INSTALLED ON YOUR PC. THEN INSTALL AGAIN THE DRIVER
1helpful
SOUND ON MY COMPUTER
Hello1
please tell me the model of your computer, so that i can find driver for that device.
However, if you have CD/DVD utilities enclosed in the computer from the vendor then install that utilities. you should install the chipset, VGA, audio and other necessary drivers. (please install that in series to avoid errors on the computer.
best regards, melnavz
Top Xtatix Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Xtatix Computer and Internet Expert? Answer questions, earn points and help others
