It will close if you push it closed. sometimes stays tight, sometimes stays open 1/4 inch.
Hello, check the freezer sliding door rail. Removed everything in your freeze
then gently slide out the freezer door. Check the bottom of the freezer for food
items that may have dripped into the bottom of the freezer. Now, the check the
roller rails along each side of the freezer there could have been widget that
got smash by the roller on the freezer door, if you find this smashed widget--he
not drunk--he is dead. Scrape the those roller rails and clean the and get all
the globs,ice cream, widgets, pieces of other different types of freezer
flub.
Next, set a level on the freezer door and see if the bubble is point
forward, if not then screw up the front two leveler in the front of the
freeze--one on each side in the front of the freezer/refrigerator. I hope this
help you. GB...stewbsion
Hi
If the refrigerator is not properly leveled the doors will
not close easily, the front side should be a little bit higher than the rear
side. If that's how it is, then the issue is with the hinge lever that seems to
have gone bad and should be replaced. Hope this helps...please post back for
further assistance.
Daniel
it's a door, not a drawer.
