SOURCE: the fireplace blower does not
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
SOURCE: 15 Amp circuit breaker keeps on tripping , as as
breaker tripping right of way means bad breaker or dead short. which means something has burned out or is wired incorrectly
My heater started FIRE!!! Is anybody will be hold responceble for this?
