Mitsubishi WS-65807 65" Rear Projection Television Logo
dion ross Posted on Oct 24, 2011
Color is fading and there's a red trail even though the convergence has been repaired.
3 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Jul 26, 2008
SOURCE: color convergence
If your model is 43UWX10B you need two STK392-110 Convergence ICs. and one each of the following 1watt reseistors. 3.3 ohm, 1.8 ohm, 2.7 ohm, 1.5 ohm, 3.9 ohm, and 2.2 ohm they are in order RK42, 46, 50, 54, 58 and RK60.
You can get replacement ICs and resistors at the following link and they provide free instalation instructions.
http://servicemanuals.vstore.ca/
Anonymous
  • 14553 Answers
  • Posted on Oct 28, 2009
SOURCE: Can not align red even though convergence board WS-55819
Did you replace the center board with the STK-392-570 chips or the Digital convergence board mounted on it?
98% of the time if you have a convergence problem it is on the center board---the small board on the left under the metal shield box stores and controls the convergence of this set.
WHICH DID YOU REPLACE?
I am here to help----I have fixed hundreds of Mitsubishi sets with convergence troubles.
Regards, SD TECH
Testimonial: "Helped narrow down where the problem is."
Anonymous
  • 2098 Answers
  • Posted on May 21, 2011
SOURCE: I can't adjust my green
If the green color can't be align anymore in the convergence alignment through the menu, this is an indication of faulty convergence board inside. Your unit used STK-392-110 as convergence chip(IC) mounted in the heat sink. Replaced this IC and some of the resistors around to have a best picture again. You may do-it-yourself if you have a knowledge in soldering and disoldering technique. Just prepare some tools and I will give you the link to order online for convergence repair kit to save some hundreds of dollar for service fee alone. Click the link below to view how much it will cost.
Convergence Repair Kit
STK-392-110
6.8ohms/1watt resistor
But before you make an order for parts, check first the board for bad solder joints(cracked/dried/cold solder) because it will do the same symptoms. Re-solder as much as possible.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified tv technician to do the job for you.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Colors are fade
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Please do us a favor and rate this solution after reading
My grandfather has a Hitachi 50ux58b and is having double vision or shadowing -- whatever it's called and redness color fading-like. Was told it was a convergence IC that needs replaced -- uncle looked...
try not to do repair yourself. the tv holds high voltage even when unplugged. you could KILL yourself. If red is fading the convergence ic will not help. you need to replace all the guns. red, blue, and green. usually each tube or gun is around 300 dollars each.
2helpful
I have a sony kp-57ws510 and the colors are fading, the red is the worse one. What Do I need to change or fix?
Tv have a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows or 3D pictures look alike?Tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.The tv convergence board must be replacing these parts to solved the tv convergence pisture problem.You have all the tools and can do basic electronic and soldering.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a tv convergence kit that belong to ur tv model and repair it ur self.The shop will cost u like $300-350 for parts and labors.
1helpful
My tv the color is fading and now in one corner it is blurry and kinda red. Not sure how to describe this.
Ur convergence is dead.Have coner blurry red colors?U must know how to solders to solved this.Must replaced 2 STK convergence ICS,and some or all it resistors.Tries Websites Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost U $300 for parts and labors.
Color!
the dull and faded color could mean you need to change the coolant.
you could also try and adjust your convergence.
2answers
Red lines running through tv
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
2helpful
2answers
Color fade on phillips 9p6034
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
  • Screen looks 3D
Problem #2 CRT Fluid is Cloudy
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Color fade
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
