if it has heat the first 15 to 30 minutes and then no heat you have bad gas coils,they are located on the top of the gas valve,just remove the two phillips screws,remove the cover and change out the coils,
Make sure the lint filter is clean. If it is make sure the hoses leading from the dryer to the outside are not clogged. It sounds like it is not getting prober airflow through the tub.
Hi, sounds like a plugged vent. Pull the dryer out from the wall and disconnect the vent.Clean out any lint and make sure you have good airflow to the outside.
I would replace the solenoids. The gas valve is not fully opening. The glow bar may be failing but the coils on the valve are in need of replacing.. Eric
how do i set this dryer to dry my clothes??? what is the right setting?? should i use the time dry setting or the more dry/less dry setting?? Clothes never dry???????????????????????????????????????????????????????
If this is a gas dryer, I'd suggest an inspection by the gas company or qualified technician. If the jets aren't firing correctly, you are wasting gas and possibly creating a hazard.
