15-Jul-2009
04:02 PM
- last edited on
15-Jul-2009
04:05 PM
Recently i bought a 6500 Classic and stupidly deleted my Authority Certificates.
After trwaling the net for info on how to re-install certificates i couldnt find an answer apart from NO YOU CANT DO THIS.
Well to that i say NUTS!!! because you can and i will show you how by simply following these steps.
1. Create a New Folder on your desktop and call it whatever you like.
2. Open notepad on your computer.
3.
Copy the text below into the Notpad file. (I got this from some website
as they were using it for smething else but it does work so thanks to
them or thanks to you if this is yours)
<?xml version="1.0"?>
<!DOCTYPE html PUBLIC "-//WAPFORUM//DTD XHTML Mobile 1.0//EN" "http://www.wapforum.org/DTD/xhtml-mobile10.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<title>Install root CA</title>
</head>
<body>
<p>
<a href="der1.cer">Download a CA Cert1</a>
<a href="der2.cer">Download a CA Cert2</a>
<a href="der3.cer">Download a CA Cert3</a>
<a href="der4.cer">Download a CA Cert4</a>
<a href="der5.cer">Download a CA Cert5</a>
<a href="der6.cer">Download a CA Cert6</a>
<a href="der7.cer">Download a CA Cert7</a>
<a href="der8.cer">Download a CA Cert8</a>
<a href="der9.cer">Download a CA Cert9</a>
<a href="der10.cer">Download a CA Cert10</a>
<a href="der11.cer">Download a CA Cert11</a>
</p>
</body>
</html>
4.
Save the Notpad file as type ALL FILES but when naming it just call it
cert.html and save it to the folder you created on your desktop earlier.
5. Now downlaod the Root Certificates you need to the same folder on your Desktop.
6. When saving the first Certificate to the folder call it der1 ((make sure not to take out the file extension eg .cer)) then the second der2, third der3 and so on and so on till you get to der11. (Dont worry this will not rename the certificate when it installs on your phone.)
Example of what the files in your Desktop folder should be called der1.cer, der2.cer etc etc.
7. Now transfer the whole folder from your Desktop to your Mobile phone. (I did this by using Nokia PC Suite.)
8.
When the folder with the certificates and hmtl we made have been
transfered to you phone navigate using your phone to that folder.
9. Go into the folder and open the cert.html file. (Your browser will now open a page with 11 download links available)
10.
Now all you have to do is click on each link and accept each
certificate remembering to save and they will install on your phone. (On
my 6500 Classic i can check this by Navigating through my phone to
Menu>Settings>Security>Authority Certificates)
Notes:-
Some errors you may receive when trying to download the certificates
through your phone browser may be Already Exists, Expired Certificate
and the most annoying is Corrupted Certificate.
Already Exists - Shouldt allow you to save (DO NOT SAVE IF IT ALLOWS YOU)
Expired Certificate - (DO NOT SAVE)
Corrupted
Certificate - Install the certificate on your computer first, then go
to Tools>Internet Options>Content>Certificates.
(save
the certificate to other people tab) Browse for the certificate you
installed then export it in DER format to the Desktop Folder you created
then start process over again to get it onto your phone.
Remember to delete any certificates as you go that you have already installed so you dont get mixed up.
Any issues reply and i will do what i can to help and if anyone has Hutchinson 3G Root Certificates please let me know.
