SOURCE: lower thread tension very loose
is the bobbin threaded correctly? the screw on the bobbin case is the point to adjust its tension.
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
SOURCE: How to adjust the tension on Elna 614de
try changing the needle
try rethreading the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
& that the bobbin is turned the correct way
SOURCE: elna sewing machine 7000 geting bobin won't go through the feed dog
sorry, not sure I understand your problem. can you elaborate?
Have you got the correct Elna bobbin for your machine? check your manual, it should have an image of the bobbin, the 7000 was one of the last Swiss made Elnas and although a computerised machine, it still tool the Elna metal bobbin with 7 holes on one side only. If you are using another bobbin in the shuttle, it may not function correctly.
if you can add some more info I will try to help you further.
