I can get into the program, but when I try to open a project, a message pops up saying "A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available". What do I need to do to fix this? I really need to get into the project I was working on. Please help.
SOURCE: Problem with Compaq Fortran & Vista
I found the solution fortunately:
It's enough to do a right click on the bottom: "Developer Studio" instead of double click, and select: "Run as Administrator" , then select: "Allow" and so on..
Try it, it works!
SOURCE: my internet explorer has stop working
try another browser, firefox or google chrome
www.firefox.com
www.google.com/chrome
SOURCE: Editor not working
OK U SHOULD CONTACT THE PRODUCT DEALER BUT ONCE U CHECK THE SYSTEM REQUREMENTS AND CHECK ALL THE COMPONETS ARE THEIR OR NOT IF ANY ONE IS NOT THEIR U SHOULD INSTALL AND IT WILL WORK AND ONE MORE U SHOULD DOWNLOAD THE ADOBE PHOTOSHOP UPDATES U CAN DOWNLOAD FROM HERE ok rate me please 100%
SOURCE: A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
SOURCE: Window Vista problem??
If you receive this error message or encounter difficulties when
attempting to launch Pro Tools using Windows Vista disabling DEP may
solve the problem.
This option disables "Data Execution Prevention", a feature of Windows
that can sometimes cause errors. This won’t harm anything, but also
isn’t always necessary.
How to Disable DEP:
1. Click "Start"
2. Click "All Programs"
3. Click "Accessories"
4. Right Click on "Command Prompt"
5. Left click on "Run as Administrator"
6. Click the Allow button if it asks you for permission
7. Type or copy and paste this into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOff
8. Hit enter and you should see the confirmation: Operation Completed Successfully
9. Reboot and DEP should be off.
If you would like to re-enable DEP enter the following into the command prompt window:
bcdedit.exe /set {current} nx AlwaysOn
Successfully. After restarting the computer, DEP will be re-enabled.
BF937-FZ7NB-KHZEY-B3LAP-BNEFL-VT3EW
hope this helps
