Try checking the plug end cap with an ohm meter for an "open line" reading.
I changed the coil on my no spark Honda G300 and reused the original resistor cap.
However I discovered it was the resistor cap that was at fault.
To fix I used a rubber boot and metal end cap from a car plug wire but new replacement caps are readily available.
Now have a strong spark.
SOURCE: Won't start, new coil, weak spark,
if i remember correctly these have electronic ignition the module may need replacing but beforedoing any thing drastic try disconecting the oil alert wire that sometimes gives a bit of pain youdoit
