I got the camera for free because mirror was stuck in upward position. I tried replacing battery pack but mirror didn't automatically fall down. I tried taking a few shots without film and shutter worked as a charm. Is there any hope for this little Pentax
SOURCE: I have an old Asahi Pentax, release lever and shutter are stuck.
The Pentax is a easy fix, maybe.. If you feel comfortable removing the bottom cover, then remove the 3 cross point screws. The battery, if installed will be loose. Looking at the bottom section of the camera, locate the tripod socket. On on side is the battery compartment, the other an L shaped lever. Under the L shaped lever is a brass plate with a slot in it. In that slot is another lever that has a spring going through the end eyelet. Move that lever toward the front of the camera until it latches on the L shaped lever above. Then try the release.
The first thing to try on the X700 is fresh batteries. Clean the battery cap and contacts with a pencil eraser.
SOURCE: Sticking shutter/unable to advance film
Probably. That camera has several rubber bumpers and gaskets in the mirror mechanism that have a tendency to turn into sticky gooey sludge causing the levers in the shutter and mirror mechanisms to get sluggish. The only real solution is to completely disassemble the camera to clean out the old goop and replace them with newer neoprene fittings. My suggestion would be to find a replacement body since the repair is probably going to cost between $80 to $90 and you can probebly find a good used body for less than that.
CameraRepairs
SOURCE: film won't advance
Pentax ME Super was one of my favorite camera, small and clean shutter release. But it has been about 25 years since it was manufactured. They happen to use rubber break within shutter unit and as any rubbers, it started to deteriorate and melt between the shutter-blades. This prevents the complete cycle of the shutter and jams the winding. You may be able to unjam the winding but eventually you have to overhaul the shutter unit. Overhaul charge is around $100 in US repair market. -James
SOURCE: pentax me super can not advance the film advance
all that was wrong with mine- THANK GOD is that the shutter was a little sticky! so i fixed it myself! yeah for me!
i thought it was really broken! but thanks to fixya.com i can actually FIX things instead of BREAKING them more! hahaha
thanks- this site is a LIFE SAVER!
SOURCE: the mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Testimonial: "ha ha yes that's what it was thankyou!"
