You don't say if your "CSX" is a battery powered watch or a mechanical or windup type watch. The solution for a mechanical watch is take it to a watchmaker. If it is a battery powered watch you may be able to do it yourself. Not all work the same way so without knowing what a "CSX" is I will give you one way to try. Pull the crown out two clicksHold the lower button in until a hand moves.You have now selected that hand to adjustUsing the upper button now, press and adjust the hand until it lines up with 12Now hold the lower button againAnother hand should moveUse the upper button to adjust this hand to the 12 positioncontinue this until all the hands line up with 12Press the crown in and press the upper button,the chronograph hands should startPress the upper button again and they should startPress the lower button and they should all go to the 12 o'clock position
Thank you VERY much Michael. I tried it and had to adjust your instructions a bit. My Michele is the battery operatied Michele CSX 36 chronograph. I pulled the crown out one time and used the top button to fix the minute counter and the bottom button fixed the second sweeper. The watch has been off center for almost a year now and within minutes you helped fix it. THANK YOU!
I am glad I could help and congrats on figuring it out! Michael
My 30 minute counter hand will not go to 0 when i press the bottom button after using chronograph feature. The second timer hand is also stuck at 4 minutes after 12 when i reset it as well. How can i fix this?
