Question about Frigidaire PLEB27T9DC Electric Double Oven
Frigidaire Dble OVen Model FEB30T6DCC Stainless (electric
Is there a way to remove the door so that I can clean the glass between? Dirty water spilled into the vents on top and of course, it shows up as a lovely dirty stream down the front on the inside. The manual only says DONT SPILL here, okay my bad. I was wiping the inside down and I spilled. I thought I could remove the front by the 3 phillips screws at the top, seemed plausible, but it doesn't budge. This stream is driving me nuts! Can you help? I called 800 number, got a foreigner, who told me I was not supposed to spill anything in the vent. Got that part, but like I said I did. They offered no resolution. There has to be a way.. Andi
  • Andi1 Sep 23, 2008
    Thank you. I did get it apart, cleaned it, and put it back together. Life is good again with a clean door!
  • 550 Answers
This exploded diagram of the door should help you get it apart, Frigidaire Dble OVen Model FEB30T6DCC Stainless (e - 4eb927f.gif It is going to be shrunk by the forum software, the full size image is
here http://www.easyapplianceparts.com/AdvancedModelSearch.aspx?ModelNum=FEB30T6DCC&mfgModelNum=&fkMfgID=4
along with a full list of parts should you need them
Posted on Sep 23, 2008
  • Anonymous Sep 23, 2008
    forgot,
    removing the door
    • open the door
    • engage hinge locks on both sides (little flip overs in the hinge)
    • close door against locks, to relax door springs
    • lift door off hinges
    install in reverse order
  • Joyce Wilson
    Joyce Wilson Nov 07, 2013
    What if the hinge will not engage
SOURCE:
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
Oven door window has streaks
you have to let the oven dry and clean and you should not put any oily foods on it..
Apr 11, 2010 | Frigidaire 27 in. Electric Double...
Have a dble frigidaire ovenand the right hinge is
Basically, oven hinges more or less work on the same principle. However, they do not normally pop out so I am reluctant to say what the problem is. Normally your handbook will tell you how to remove and replace the oven door.
If you haven't a handbook, try the manufacturer or repost under the Frigidaire section.
Nov 24, 2009 | Stoves 720EF Electric Double Oven
Spills in between glasses of the oven door.
The door must be taken apart at least most of the way to clean glass. Just so you know, this is a problem with a LOT of the newer makes and models. If there are 2 screws behind the handle, take them out and some of them come apart enough to get your hand a paper towel in to clean. Otherwise, the door must be removed and completly diss-assembled.
Mar 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Glass door on oven has water marks between glass
you have to remove the door and take it apart in order to clean the glass. that is the only way. Joe
Nov 18, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Oven window
in your manual the is a section about how to remove the oven door. after removing the outer panel is removed by a few phillips screws around perimeter, of panel perhaps 2 for handle need to be removed depending on model. not a terribly difficult task, but take time and youll be fine
Nov 06, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Glass oven door
We Use DeBruce Polish on all our cooktops. DeBruce also works on stainless steel and polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
Oct 27, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Dirty oven window
Try to remove the door. For the Kitchenaid, thereis a hinge on each side with a latch that flips up. Once the door is removed, remove all screws and you should be able to get at glass. Be very careful, the Kitchenaid had four panes of glass.
Jan 08, 2008 | Whirlpool GBD307PRS Stainless Steel...
Frigidaire PLEB27T9DC Electric Double Oven Logo
314 people viewed this question
Top Frigidaire Ovens Experts
Marvin
Marvin
Bruce Denton
Steve Allison
Steve Allison
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
