https://printcopy.info > brand=Kyocera > code=7900
Kyocera FS4100DN · Code: 7900 · Description: Drum unit EEPROM error. No response is issued from the device in reading/writing for 5 ms or more and this problem is ...
NITIAL FAULT IS ERROR CODE DUE TO WORN BLACK DRUM GIVING PATCHY IMAGE, ON FITTING A NEW DRUM IT CREATES ANOTHER ERROR CODE ABOVE E020, ON RE-FITTING OLD ONE ERROR DISAPPEARS. PATCH CREATED ON ITB IS UNDERTONED DUE TO LESS INTENSITY LASER BEAM PASSING THRO, THE RESIDUE ON THE GLASS, HENCE E020-0023.
THE CLEANING TOOL ON THE DOOR IS INADEQUATE TO CLEAN THIS RESIDUE. PULL OUT PROCESS UNIT TO MAX. LIMIT. PRISE UP THE DUST SHUTTER, THEN CLEAN WITH DAMP WIPE AND DRY IT. REPEAT IF NECESSARY OR TAKE LASER UNIT OUT
This is NOT an error code...the machine is simply telling you that it has run/printed a certain number of pages and it will soon be time to replace the drum.
Hi error code refers to a drum drive motor error code,
more than likely you have a tight Drum. remove drum and see if you can turn it by hand if not replace the drum unit
E751 (0302) code is not found in the Service Manual. This code is addressed in Tech Pub TP03 125. The code refers to a memory writing error in the magenta drum unit. Check or replace the magenta drum unit or the Memory board (Memory Board part number is FG3-2345-000. E751 The connection of the drum unit /toner container is faulty. The mark x indicates color [Y=1, M=2, C=3, K=4]. 000x The connection of the drum unit (at the printer side) is faulty. 100x The connection of the toner container (at the printer side) is faulty. 010x Built-in memory writing error in the drum unit. 110x Built-in memory writing error in the toner container. 020x Built-in memory data error in the drum unit. 120x Built-in memory data error in the toner container. 030x Built-in memory writing error in the drum unit (When the number of retry exceeds the specified value) 130x Built-in memory writing error in the toner container (When the number of retry exceeds the specified value).
SPECIFICALLY...you need to replace the Black drum unit. the sequence of that particular error code is; E020-01XX(Yellow drum) E020-02XX(Magenta drum) E020-03XX(cyan drum) E020-04XX(Black drum)
