LG LRTP1231W Top Freezer Refrigerator Logo
danesh rampersaud Posted on Oct 20, 2011
Lrtp1231w refrigerator is not geting cold but freezer works good what part should i change
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 14 Answers
  • Posted on Oct 21, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
14
Questions
0
Helped
1897
Points
35
I don't know how your unit works but most have a thermostat that opens a vent between the freezer and the fridge allowing cold air into the fridge compartment. you probably need a new thermostat
which looks like a wire with a tube on the end, check for a service manual on the manufacturers website to find part numbers and diagrams
Vegetables freezing in lower trays
lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
Lg refrigerator is not cooling
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Refrigerator, doesn't get cold but freezeris cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Freezer compartment is always icing over
heatman101
LG fridge not cooling and instead getting hot inside
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Frezzer is working fine but frig just dont seem to be geting realy cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
The Fridge froze all inside and the generator works constantly. The settings are set to medium. Nothing changed after turning the power off and then back on after a few seconds. I'm assuming the thermostat...
Check the vent door from the freezer to the refrigerator...when you turn the refrigerator off with the knob, does the vent door close. The bottom of your refrigerator works from the freezer blowing cold air through the vent to the bottom of the refrigerator. If it is turned all the way down, that should shut off the flow to the bottom. If any thing is broke there, it will continue to let cold air come down the vent, so check it out. The vent knob itself might not be working to turn the vent door down or off. There also, is a relay on the back of the refrigerator that controls the compressor on and off...it could be stuck in on position.
Amana refrigerator not cooling below 45 degrees.
the fan in the freezer section is called the evaporator fan. this fans main funciton is to blow cold air into the fresh food side. if its not running then you need to replace. make sure there is no frost build up on the rear wall in freezer section
1helpful
The food side not geting cold I set up the control nothing
the small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
