You push a tab and a portion slides out. The piece that slides out looks like you would mount the staples and just slide it back in. But that isn't how it works. Instead, you simply place the staples {pointy side up} in the spot where the portion slid out. You slide the portion back in over the staples. I've attached a pic, that shows the staples in the correct spot. Hope this helped, this boggled me for a few days until I figured it out.
SOURCE: Powerfast strap gun for romex misfiring
just a try spray with a generous coat of pb blaster while firing a few then follow with a good coat of household oil then oil before using just something to give it a try
SOURCE: I have a PowerFast staple gun #31600. Can not
I got some staples stuck in my Powerfast 31600 too. I THOUGHT they were the right staples, I was wrong. You have to bend a little tab on the bottom of the stapler to let the slide come out of the back. Then you can remove the staples. Replace the slide and tap the tab back into place with a punch.
SOURCE: I need to replace my
http://www.bizrate.com/staples/powerfast-staple-gun-31600/
Well there is a link, also Ebay has them too i believe.
SOURCE: How do I load my
Howdy, I don't have pictures, but that model is loaded from the bottom (not the back,as one might expect) while the plunger is pulled to the rear then pushed back in once the staples are laid in the track on the bottom. Handy once you get used to it:)
Regards, Farmerbear
