F3
display in ur diswasher means...its purely on Electrical Heater Fault...this may Controller failure to
communicate with the
Atmel 16 on the powerboard. The dishwasher
loads will not function..this fault can be visible in the
first 15 seconds of initial power-
up. “F3” will flash on the
display and will be visible to
the user. Dishwasher will be
disabled.if this above problem persist in ur dishwasher means..
i suggest my solution tat u Check Control and Power Board Compatibility. Check power/controller board communication
cable...
can u pls tell me whether u got a three long beeps before display f3 message...
if this problem persist means..in this problem the fault occur in Low inlet water pressure.so Press Cancel key twice to
reset this fault. Ensure that
Inlet hose is ON.
Replace Flow Meter.
Replace Inlet Valve...if ur not familiar with electronic components means ..try to get assist from technician..while replace the parts
thanks for using fixya
rate this solution..
Hi!!!!
try to check the sensor!!!
or open and un screw check the wire
if it ok!!! use tester!!!
Have to tried turning off for for 5 minutes that back on see if that resets it
I believe mine needs a thermostat.
Error Code/Message - Oven - F3 Error Code - F3 E0
Control displaying F3 E0:
There may be a problem with the Oven Temperature Sensor, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
