No the tv is completely unplugged from all power sources and it still makes the high buzzing noise it was fine this morning at 10 am and it started buzzing about 12:20 so I unplugged it and left it for a while and it's still buzzing nowNo the tv is completely unplugged from all power sources and it still makes the high buzzing noise it was fine this morning at 10 am and it started buzzing about 12:20 so I unplugged it and left it for a while and it's still buzzing now
You can't post conmments that contain an email address.
I have encountered numerous issues like this one. Normally, when you unplug a refrigerator, all mechanical noises should cease operating. A buzzing sound may be emanating from some other appliance, clock, or other product in close proximity, transmitting a frequency toward your unit. Basically if there is no power supplied to the unit, it virtually can make no noise.
Nov 8, 2015 - 25 posts - 12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
Try this method : 1. Menu, select setup 2. Plug and Play 3. Enter pass code by entering 4 digit number (0-0-0-0) 4. Select language 5. Switch to Home Use 6. Follow the instructions. Good luck.
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
