Re: Dont know how to load answer message on answering...
Press and hold the GREETING/PREVIOUS button. Record your message after the tone. Release the button when done. You can download a copy of the manual here.
www.technibble.com > Forums > Other Discussions > General Chat
Dec 9, 2013 - Recovering deleted messages from a digital answering machine ..... AT&T cordless phones - I don't know how similar that would be to Uniden.
forums.verizon.com > ... > Home Phone (Landline or Digital Voice)
Mar 16, 2015 - I have to say, though, I doubt you'll be able to recover the messages. Digital answering machines typically don't have an un-delete. Good Luck.
Dec 14, 2013 - Delay needs to be at least 30 seconds because voicemail takes just over 30 ... If you don't know your four-digit pin, it's possible you haven't ...
It seems that your messages are full. This will happen if you dont delete all messages. Try that first. Then try the answer button. Sometimes we turn it on but forget to actually have it answer calls. Make sure your rings are set to 4 rings then you will know if it will answer after 4 rings. If it still won't answer after 4 rings then junk it. They are so cheap to buy a new one. They are not worth fixing these days. it is sad i know. Good Luck
Call your phone number. After the greeting is finished and you hear the beep to leave a message push 123 on a touch tone phone and you will be given a list of things you can choose to do including listening to messages. 123 is the default security code unless the security code has been changed. Since you dont know how to retrieve messages Im assuming the default security code has never been changed.
If 123 is not the default security code and you dont know what the code is, you can change your code in the setup menu. You get to this by pushing the stop/set button on the answering machine and holding it for a couple of seconds. Since GE doesnt offer a downloadable manual for the 29878GE1 you should probably take a look at the manual for the 29875GE1 which is basically the same model with the addition of a digital message counter. Hope this helps.
Press INT (Bottom right black button) then # then follow instructions.
Press 4 for new messages and 5 for all messages.
To turn answer machine on and off – press INT, #, 0 to turn
it off and INT, #,8 to turn it on.
My question is how to change answer machine message, any
ideas?
push "GREETING" button and hold. It beep and you can record your new message while you hold it down. When complete release button. To play back just push button and release.
