Short answer- no problem, but please read on...
First, economics are an issue- there is more than one way to convert VOLTAGE, the ;best' in this case is by using a heavy coil-wound TRANSFORMER (not simply a device being called a transformer or 'converter'; terms often misused) but virtually NO means of converting FREQUENCY (60Hz USA vs 50Hz Eu)
Extended use at wrong frequency has been known, by personal experience, to cause overheat and premature failure of many devices.
Heat is an issue for a hidden reason in the classic models due to their 'mechanical fuse' which is designed to limit serious damage in event of overload (too thick batter mixed for too long)- the device will yield at lighter work-load as the moter heats to greater levels- it is prudent to be always aware of the 'running temperature'.
There are subtle differences in the motor winding design, and you may find difficulty finding repair parts for any relatively minor electrical issues (mechanicals are the same in classic models)
If you have talent for house wiring better to use seperate 220 line, as if for a dryer or electric stove- its more efficient overall.
If you have 60Hz 220 V mixer, (most are 50Hz 'tuned' at 220Volts) a step-up transformer to bring your US 60Hz current UP to 220 volts to suit your mixer will not harm your mixer if it supplys sufficient Amps or Wattage (you likely must convert; Volts multiplied by Amps gives Watts)... But you can easily pay out near half the cost of a mixer to get a quality transformer into your kitchen and still, it remains a weak-link; you can only get quality if you pay for it...
...but the 220V outlet permits use of commercial appliances with all the durability, convenience, and prestiege they afford.
Artesian models with 'soft start' and inverter-technology speed control use much more electronics to feed the motor- they should be supplied as close to true sine-wave power for the same reasons as computer UPS battery back-ups.
In general, and by experience, its best overall to buy the appliance designed for use in the location required. If you feed the appliance the power it was designed to use it has no way of knowing how it got there. The question mark is with the output of the power conversion device.
