Amana oven will not light. If the burner does light, the flame goes out after a minute or 2. Most of the time, the ignitor never glows at all. Sometimes, it glows and doesn't light the burner. Other times, lights and then goes out. The control panel defaults to the standard clock setting. nothing.
Hello Richard, Do you see the ignitor glowing in the oven yet no flame to the burner??If yes ya see the ignitor..while it seems strange the ignitor is the problem and its not getting hot enough to allow the gas to flow to the burner...by replacing the ignitor it will repair the oven.
Let me know it the ignitor does not seem to be glowing and i will tell ay how to check it since by far its very likely the problem.
Most probable cause is a weak bake burner ignitor,if you can remove the floor of the oven and see a orange glow but within one minute thier is no flame the ignitor that glows is weak and needs to be replaced,if no glow at all ,if your capable find the 2 wires to the bake ignitor,using a volt meter set to AC volts there should be 120vac to the ignitor. If their is 120 vac and absolutly no glow the ignitor is cracked and needs to be replaced,if their is not 120 vac it could be the gas safety valve or control
that ignitor should lite the flame within 40 to 60 seconds if not the ignitor is bad.even though it glows red it doesn't mean it's good it works with amps change the ignitor
If your dryer heats when you first turn it on and after a few minutes it does'nt. check the ignitor to see if it is glowing. It should glow bright then you will hear a click and the burner will light. If the ignitor glows bright but you hear a click but no flame and if you watch this for several minutes and this process continues of glow then glow goes out no flame, then you have a bad burner coil. There are 2 black solenoids sitting on top of gas valve. One of them is shorting out after it warms up. Replace both solenoids. You can usually get them as a kit from parts store.
Watch the burner assembly, shortly after starting the
dryer the ignitor should begin to glow. If it glows for several
seconds (up to 15 seconds) and then goes out, then the problem
is probably the solenoids (coils). If the ignitor glows and stays
on, then the problem is usually the flame sensor.
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Sounds like that ignitor is weak. When the ignitor glows it builds up resistance to the gas valve for gas to come in. If it sometimes takes 10 min then the proper resistance isn't there and this will give you that gas smell. Replace the ignitor and this should solve your problem. Can expect to pay $80 - $100 for the part.
