SOURCE: not able to connect to USB MIDI of my Casio CTK 810i
On reading specs, use of the USB is NOT supported on a MAC or on other than the 32 bit version of Vista. If you happen to have the 64 bit Vista, it won't work. All the other versions of Windows seem to be supported..
SOMETIMES one must install the software BEFORE connecting the USB cable to the unit. SOMETIMES one must install the drivers in SAFE MODE. These things are ridiculous, but some of the quirks of Windows are stupid.
SOURCE: Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
SOURCE: Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
SOURCE: Casio CTK 810 with Windows 7
You need a midi to usb interface, otherwise it is quite simple. I personally have an M-Audio interface that plugs into my midi out and plugs into your usb port on your computer. Once done, you can create a profile in Reason for your CTK. Windows 7 will notice the M-Audio device and then you will be able to use midi. You may have to install a specific driver for the particular M-AUdio device (or another midi to usb interface) but that is simple. You do not have to worry about a driver for the keyboard.
In my experience, M-Audio makes about the best midi/usb interface, and they come in all popular configurations. I use a very small 1-to-1 interface, though there are multi port interfaces one can buy. I purchased mine on eBay, though you can find them at Guitar Center if you have one in your City, or alternately Musiciansfriend.com web site. Many online stores sell them though. You amy want to use Amazon or a price comparison web site to find your best deal.
Thank you for using FixYa, and good luck.
SOURCE: I have Casio Ctk-496 and
Casio Chord is internal to the keyboard and doesn't come out on MIDI. Transpose is similar and while the button may send a MIDI transpose type signal out, the notes will not transpose in your computer...
Testimonial: "Thanks! Something I learned."
