GETI CHECK SALE [F2]
PAYROLL/BUSINESS [F3]
MORE
VERIFY ONLY [F4]
Press the Purple key below the More option.
GETI CHECK SCANNER MENU [F1]
BATCH MENU [F2]
REPRINT [F3]
MORE
VOID [F4]
Select Batch Menu [F2].
ERASE BATCH [F1]
CLOSE
BATCH [F2]
HISTORY REPORT [F3]
BATCH
REPORT [F4]
Select Close Batch [F2].
KEY IN MANAGER PASSWORD
AND PRESS ENTER
Press [1] and [Enter].
ARE YOU SURE?
CLOSE BATCH [F3]
CANCEL [F4]
Select Close Batch [F3].
DIALING . . .
The terminal will dial in to close the batch. Once closed, the terminal will
print the batch report indicating Batch Accepted.
See example below.
BATCH ACCEPTED
EXIT [F4]
Select Exit [F4] to return to the menu.
The Batch button allows you to count bills in batches from 1 - 999. For example, if you want to sort into piles of 100 bills, the machine will count 100 bills, then stops. Once you remove those 100 bills, it will continue to count the next batch of 100 bills, then stops again. The machine is preset to common counting mode, To count bills in batches, press BATCH. Batching is preset to 100 bills. To change batch amount, press C to clear, and use the keypad to enter a batch number between 1 and 999. Press SET to save the setting.
