SOURCE: Audio volume controller not properly working
I am not sure about the solution, but I had a similar problem. My technician opened up the controller and cleaned it physically, this solved my problem. I hope it solves urs too.
Regards.
SOURCE: Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
SOURCE: x-540 speakers no sound rear speakers
rear speakers are not designed to put out the same output as fronts. They are for supplemental sound only, to make it seem like there's something happening behind you.
SOURCE: Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
SOURCE: I just got a pair of Logitech LS21 2.1 speakers
Depending on the software that runs the sound card (you can find it in the control panel), the ports may be configured differently than they used to be. Check in the control panel and see if there is way to adjust the "plugs" and what they mean. Some of the sound cards allow you to change your mic to a sub and your input to an output!
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
hope this helps
