Can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
SOURCE: cant login to y.m but can connect to internet,
I would like to help you with your issue. but we have to check the following first
http://webmessenger.yahoo.com/ try log into the Web Messenger
> Step 1: Test Your Internet Connection
> Step 2: Verify Your Yahoo! ID and Password
Open Internet explorer and www.mail.yahoo.com
Check by sign in to you account
> Step 3: Test Your Access to Secure Pages
Make sure that you can access secure pages from Internet Explorer
Try to sign in to Yahoo! by going to the Yahoo! sign in page and enter
the same Yahoo! ID and password you were using before.
> Step 4: Verify Credentials
Verify that the same Yahoo! ID and password you used before in the last
step also works in the online version of Messenger, Yahoo! Messenger
for the Web:
enter the same Yahoo! ID and password you were using before.
> Step 5: Check Connection Settings
Click the Messenger menu and select Connection Preferences.
Click Connect directly to the Internet, and then click OK.
Check by Changing the connection type to a connection via a proxy server:
Click Connect via a proxy server, then under this option, select HTTP proxy, and then click OK.
Last is Uninstall all the Yahoo Tool Bars and Yahoo applications , Yahoo Messenger, and Yahoo Updates from Program list i.e Control panel - Add/Rem Programs ..
And reinstall the Yahoo Messenger again -
Hoping this article will be helpful for you
SOURCE: help me to solve my problem
Test your account with web messenger by logging in here:
If this fails, it means that there is a problem with your userid, password or account. Contact Yahoo for assistance.
If this works, then proceed to the next step.
Ensure you have a good stable internet connection.
Uninstall Yahoo Messenger and everything associated with your messenger.
Download the latest version from messenger.yahoo.com.
Try to log in again.
This should work and fix your problem.
Let me know how it works out and don't forget to give me a good rating as well as your vote.
SOURCE: Checking virtual IP servers... [VIP Raw]
1) Clear your browsers out
Download 'ccleaner' and use it daily. Run it through a couple of times,using the factory settings and the 'Run Cleaner' control until 0 bytes are seen to be cleaned following a scan
Run the 'Registry' from the left hand toolbar but 'Save' any changes after opting to 'repair' errors.Never make changes to your Registry without saving the information.
http://www.filehippo.com/download_ccleaner/
Open Internet Explorer (even if you use another browser as default) > Tools > Internet Options > Connections tab > LAN settings > Uncheck all the boxes and check "Automtically detect settings" > Save > Save
SOURCE: hi cannot able to connect
Please uninstall the messenger, download and install latest yahoo messenger and try. Still if you are failed, try login with http://webmessenger.yahoo.com, let us know the result.
Thanks for joining us.
Have a good day.
por favor solucionen mi problema no me deja abrir mi msn dice que mi cuenta a sido bloqueada y que tengo que desbloquearla , ayudame por favor desbloqueela en codigo de desbloqueo es 81003003 ese codigo me dan para entrar ahi
[VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.32... [FAILED]
*** 'COMPONENT_TYPE_WININET' value: '12029' ***
[VIP Raw] Resolving host name vcs2.msg.yahoo.com... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.186.241... [FAILED]
[VIP Raw] Resolving host name 98.136.48.100... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.100... [FAILED]
[VIP Raw] Resolving host name 98.136.48.110... [PASSED]
[VIP Raw] Connecting to Virtual IP server 98.136.48.110... [FAILED]
[VIP Raw] Resolving host name 67.195.187.228... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.228... [FAILED]
[VIP Raw] Resolving host name 67.195.187.229... [PASSED]
[VIP Raw] Connecting to Virtual IP server 67.195.187.229... [FAILED]
[VIP Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'YMSG.ColoSelectionFailed' ***
Checking HTTP virtual IP servers...
[VIP Http] Resolving host name httpvcs1.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.48.229... [FAILED]
[VIP Http] Resolving host name httpvcs2.msg.yahoo.com... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.139.61.47... [FAILED]
[VIP Http] Resolving host name 216.155.194.137... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 216.155.194.137... [FAILED]
[VIP Http] Resolving host name 98.136.112.142... [PASSED]
[VIP Http] Connecting to HTTP Virtual IP server 98.136.112.142... [FAILED]
[VIP Http] FAILED
