SOURCE: Ipod doesn't show music in artists, only in albums.
Go to Get Info and unclick "Compilation". If it's a compilation it won't show the different artist, which is actually a cool idea.
SOURCE: I can't make my archos
Select the Show playlist menu item while you are in the Music
browser. A playlist panel will open on the right: you can now start
adding songs to the current playlist. In the left pane, locate the
songs you would like to add to your playlist. Highlight a song and
press or OK to add it to the playlist (the song’s icon in the left
panel will change to, indicating that it is part of the current
playlist). Repeat this operation with all the tracks you want.
You can also add the content of an entire folder, artist, album, etc. if you highlight it and press OK.
Another way to add songs to a playlist is by using the Add to playlist or Insert in playlist menu items:
Add to playlist - will add the highlighted track, folder, artist or album at the end of the playlist.
Insert in playlist - will insert the highlighted track, folder, artist or album before the selected item in the playlist.
Note: a playlist can have a maximum of 5000 songs.
You can use TextEdit application to Add/Delete/Move the mp3 song in the playlist.
For example the playlist file you just created has the default name untitled playlist.m3u and there are 2 songs included:
/Music/Danielle Davis/I'm Sorry.mp3
/Music/Danielle Davis/Outta My Dreams.mp3
If you want to Add another song from a different location (ex.
Slobberbone folder, song name: slippage.mp3), then you just need to
open the untitled playlist.mp3 file with TextEdit and add another line
to:
/Music/Wes Burden/ Brave New World/Brave New Wold.mp3
Save the untitled playlist.m3u file again and close. Next
time when the untitled playlist.m3u is opened, you will see that there
are four mp3 songs included.
Note: to delete a song in the playlist, simply delete the line which contains the title of the mp3 song.
If none works, Firmware update is an option.
Download the firmware from Archos Website.
Connect the device to the PC.
Go in “My Computer”, you should see “Archos 504/604”.
Copy/Paste the firmware downloaded on “Archos 504/604”
Disconnect the device safely. Go to Setup > System > Update Firmware.
You can also copy the firmware update file to the root of the
device, and select while browsing the hard drive content with the
“Browser”.
SOURCE: code 104
Recovert code 104
would you like to recover your system?
NO
Repair disk
Format disk
P.S. pressed the OK button on the device and its telling me to
connectto your divise to my PC and install an update file DONE
then the devise reapear back to recovery code 104
SOURCE: MP4 player
Press the mode button on mp4 player to find the music directory and select what you want to change to.
