SOURCE: Playstation 3 audio connection into Yamaha HTR-6040 AV Receiver
Solved problem with Yamaha HTR-6040 AV Receiver. My daughter had inadvertently changed the program to "Direct Stereo" mode which allows sources to bypass the decoders and DSP processors so you can listen to 2-Channel PCM and Analog sources. Nothing to decode digital audio in this setting!
SOURCE: yamaha rx-v1800
I think the Yamaha will not upconvert anything below 480p through the HDMI output. You'll need to use the component out to the TV.
SOURCE: different sound levels dvd and cable hdtv yamaha htr-6130
Well, first of all, the method you are using is the lowest quality. You should upgrade to a toslink(digital optical cable) or a digital RCA cable. The toslink is the best all around. But it is normal for some devices to have higher sound output than others.
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
SOURCE: no analog comming out of receiver when optical input is used .
as a rule...in order to get analog audio out of a receiver, it must have an analog input. you could use a digital to analog converter between the tv and stereo or come out of both of your source devices (ps3, cable) with analog to the receiver. good luck
