SOURCE: Won't turn on...
It's possible that the convergence IC's may be bad in this set along with a few resistors. A TV repair shop should be able to fix the set for you.
SOURCE: samsung hcm4216w
The most common problem for those symptoms are convergence amps. That unit takes two stk392-040 Sanyo Ics and will most likely require that several low ohm resistors (3.9 ohm-2w) be tested and possibly replaced.. There is one last thing also, a pico fuse at Fd102 (3.5a) that sometimes opens and would need to be replaced..
The convergence board in these is easily removed, so an in-house service call could be done...
Hope this helps
SOURCE: samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
SOURCE: We have a Samsung TV
You can get the service manual for your model at the following link and they will help assist you in troubleshooting the set froo free . They email the service manuals out within minutes.
http://servicemanuals.vstore.ca/
SOURCE: Samsung PCL545R Projection TV
Pull out the plug for the TV and leave it out for one hour at least. Plug it back in and it should be ok. It will re set itself.
