Question about Viking VDB200 Dishwasher
The lights of my Viking dishwasher VDB200SS are flashing and do not stop even if I reset the unit by pressing start for more than 4 sec. The pump is running when I connect the unit to electric power for a short moment (3 times) and the removes water in the unit. The flashing lights are: Pots/Pans : Normal Wash : Econo/China : Rinse/Hold : : Hi Temp Wash : Delay Start. Only the Start button is not flashing. Is there a solution without customer service because I am not in the US at the moment with my dishwasher. Thank you!
  • Viking Master
  • 2,605 Answers
Hello Jo, welcome to FixYa.
Based on your post, I suspect you mean the drain pump is running as is common for Asko built machines such as your Viking with this scenario/error. I have good news...It is likely nothing very serious, but the "resolve" requires some investigation on your part.
What this usually means is the control has indicated a overfill. All the indicators flashing is the error code for overfill/drain error.
**before proceeding turn the dishwasher power off via the home breaker panel, or unplug it from the wall if that is possible...most are hard wired to the home electrical...safety first**
The first thing to do is remove the toe panel/kick plate and inspect the base for water. There will likely be water present.
With the aid of a sponge, towels, or a wet-dry shop vacuum, absorb the water from the base, that should restore normal operation...it should be known that if you leave the unit for a few days, the water in the base will evaporate hence appearing as everything is fine again...if any other problem/leak does exist it will return.
If the unit works fine after resetting the power/breaker and soaking up any water present, it can likely be chalked up to a drain back-up or obstruction in the drain hose or pump...
(it could mean a faulty drain pump or a inlet water valve, so you'll need to pay close attention the next few times you run it)
**The float is primarily the last ditch safety to prevent disaster in the event of a overflow, back-flow, or leak underneath the unit activates the pump-out non-stop
letting you know to service or call for service to the unit**
Hope this helps move you forward, or even better resolves the issue altogether. Let me know of course, I will help you move further if necessary. Good luck.
Regards,
Macmarkus :)
Posted on Oct 17, 2011
SOURCE:
My viking vdb325ss dishwasher runs for a few minutes and then stops with control pad lights blinking. The "normal cycle" and "pots and pans" lights blink together. I have reset and restarted the dis
Hello Peter!
Your owners manual or a call to Viking should help you decode the blinking panel lights. They are not random and are a desperate cry for help from the machine.
It has been my experience (YMMV) that a common dishwasher problem in older machines is accumulated grunge (the technical term) in the water level sensor. In many cases the sensor lives in a plastic container on the side of the DW and although the designers try hard to avoid contamination, the container eventually loads up and intermittently jams the float.
Before I pulled the unit however, I'd check the bottom of the wash cabinet for contaminants. There may be an screen (under a cover plate) that has clogged.
Your situation sounds a bit different, since my Samsung did not pump out water, it just stopped and flashed a code, but who knows? Go for the low-hanging, common issues first.
All the best.
Nov 23, 2014 | Viking VDB325SS Dishwasher
I have a misled g843scvi dishwasher. The intake/ drain light is flashing, machine start then fails. Any ideas
Hi
Thanks for using FixYa. The first thing that should be checked is if its draining properly as it could be that the drain hose is clogged and needs to be cleaned. The drain pump also should not be clogged. Also the stopcock should be opened fully and the water inlet valve should be checked for any clogs. Also the metal filter, impeller cover and the air gap unit should be checked. After checking this you can reset the error as follows: turn the rotary selector switch to "Stop/End" or press the "Start/Stop" switch for approx. 5 secs. Then switch the appliance off and then back on again. Please revert back for further assistance.
Thanks
Rylee
Dec 23, 2011 | Miele Dishwashers
The normal and economy lights are blinking and cannot get to wash through a full cycle. water is in the bottom of the washer
You will have to check if the dishwasher is stuck in the drain cycle or wash cycle.
The normal and economy lights flashing means there is flooding in the unit.
Reset the unit by pressing START button for 4 secs. If the flashing does not stop then you have to call the technician. There may be a leakage which is causing the flood switch to activate.
May 21, 2011 | Viking 24 in. Professional Series VUD040...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Viking (made by ASKO) Dishwasher Problem
You can find parts, solutions and manuals at link below. Hope this helps, Sea Breeze
Click below
http://www.retrevo.com/s/Asko-D1716-Dishwashers-review-manual/id/21338ci577/t/1-2/
Dec 18, 2008 | Asko D1716 Built-in Dishwasher
Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
Nov 17, 2008 | Viking 24 in. Professional Series DFUD140...
Flashes 8 times ADP 5340
Again Pressed the main button for about 15 sec that did reset the fault
larf
Apr 20, 2008 | Whirlpool 24 in. ADP5966 Free-standing...
Viking VDB200 Dishwasher Logo
5,908 people viewed this question
Top Viking Dishwashers Experts
Pierre Laplante
Craig Butler
Craig Butler
Mike
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
