Question about Sharp Refrigerators
I have one sharp fridge got problem... Model: SJ-PT71R-HS. Fault: front panel no display,fan motor and LED lamp no function .only the compressor run....
    Sergeant:
    Champion:
  • Sharp Expert
  • 279 Answers
Checked main PCB mounted back side of Ref.
If Main PCB is ok then Fan is defective.
Posted on Jan 15, 2016
SOURCE:
dcp2
  • 63 Answers
SOURCE: Kenmore fridge won't run after cleaning fan motor
Check the thermostat and make sure it is sending power to the compressor and fan. If the light comes on when you open the door then you have power to the unit. Make sure you hooked all the wires back up and in the right location
Posted on Jan 27, 2008
BNewberry
  • 93 Answers
SOURCE: fridge/freezer not cooling
I will be more than happy to help you out with this.  I am a factory authorized servicer for Frigidaire.
Read this Article first on Frigidaire Refrigerators not Cooling.  Then if you have any more questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Posted on Nov 08, 2008
SOURCE: GE French Door Control Panel LEDs Off if Fan is on.
Solved my problem. Replaced the motherboard. P/N WR55X10552. Purchased on Ebay, $70.00
Posted on Nov 17, 2008
landsend
  • 1066 Answers
SOURCE: freezer cold, fridge warm
The small cooling fan in the freezer compartment that sends chilled air to the food side is defective and needs replacement.  Sometimes that are only frozen stuck.
When you receive advice from this website you have to understand that without the item in front of us, we are only able to provide "a best guess" as to what the problem might be based on you description of the defect.  If you haven't described a clear and precise description of the defect you decrease the chances of an accurate reply.  Thank you.
Posted on Apr 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: My fridge is not cold though the compressor is running.
If any fans stop cooling stops. The fan inside the freezer will need to be examined for why it stopped or if the one below is stopped it to will need to be checked. I think your defrost timer is on the front of your refrigerator on floor behind the kick plate. If you can turn the timer clockwise until refrigerator starts or stops that may tell us the reason for these failures. Place your model in the model search feature below and choose one of many the same models. Look inside back of freezer wall after you unplug refrigerator and tell me if fan is stopped and if coils have ice or snow covering them.Then we will go from there.Click link below. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on May 24, 2009
Hi, I have a Lanona HJA6110 American Fridge Freezer. The Freezer works, but the Fridge doesn’t and I get the high temp. Light flashing on the front display panel. Upon opening the Fridge door the fan runs...
Go to Amazon.com or click on this link.
https://www.amazon.com/gp/product/B00W4YG47S/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
Supco SM0146B Refrigerator Evaporator Fan Motor, Replaces Samsung DA31-00146B
The fan motor is essentially a universal fit on several brands of refrigerators. you will have to save the wiring from the original fan and attach some terminals for the replacement fan
Aug 07, 2018 | Refrigerators
Sharp refrigerator Model SJ-TD555S. Fridge won't cool. Freezer section frosted over and not defrosting.
You are not getting enough air flow over the coils. First, unplug it so it will defrost. Vacuum coils (back or underneath). Do not cover up the air vents inside the refrigerator. Check if the compressor fan is spinning. If all fails, you may have a refrigerant leak.
Apr 12, 2017 | Sharp Refrigerators
I bought sj-5501 Sharp fridge . Yesterday I have no lighting on the front panel display of the refrigerator The refrigerator works right What could be the reason ? Thanks,
You can try one of these;
1. Hold down "Energy Saving" and "Lighting" buttons simultaneously for 10 seconds (or top left & right buttons). Display panel returns immediately
2. press the Freezer and Ref buttons at the same time for 8 secs and Bam!!!! Bac 2 normal!
3. pressed the power freeze and vacation buttons for about 3 secs and it worked
4. I held the top left and top right soft touch buttons on the screen itself (which I think is the power save and the lighting buttons) and held for about 8 - 10 secs and it reset
Hope it helps. Its in the combination of two buttons pressed simultaneously. Try your luck.
May 16, 2016 | Refrigerators
Failed led lamps or boards .
You can't. The leds are in side of the panel, and you cannot get the led replacement kit. Last I heard however is that sharp has been covering a lot of sets that have this problem. You should call them and gripe and see what happens.
Mar 21, 2013 | Sharp Televison & Video
How do i replace the led lamps on my sharp 60 inch tv ?
You need to call sharp and see if they will work with you on this. They have been covering this repair for a lot of people. You cannot get the required led replacement kit. Only sharp auth servicers can get them. Plus the leds are inside the panel. You would need a clean room in order to keep dirt out of the display.
Mar 21, 2013 | Televison & Video
Sharp projector Bulb replaced but still won't work?
check the ballast
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Nov 08, 2012 | Sharp Projector Lamp For Xv-z90 Xv-z90e...
How do change the ref bulb on sharp ref model sj p43n - sl
Unplug the refrigerator. Remove the lamp cover by lifting up at the bottom of the cover. Then unscrew the old bulb and replace with an identical appliance bulb (Base E12, 240V, MAX 15W, T-20). This bulb is at the top center of the fridge.
The manual is available here: http://safemanuals.com/414159.php?ID=1286636&k=3942fa3f433aa4c53ff8bcb7d07ae8e8&q=SHARP%20SJ-P43N/P47N/43N/47N . You will need to review the fridge or enter a code to download the PDF. The light replacement instructions are on page 6.
I hope this helps.
Feb 25, 2011 | Refrigerators
LED front panel displays
This model does not have a channel display.
Oct 08, 2007 | Mitsubishi HS-U447 VHS VCR
Refrigerators Logo
236 people viewed this question
Top Sharp Refrigerators Experts
geob91
Elie Balas
Vernon Taylor
Are you a Sharp Refrigerator Expert? Answer questions, earn points and help others
