Carrier 38CKC060 Air Conditioner Logo
umer gugu abdi Posted on Oct 17, 2011
42sd7c price free standing vertical focus 5ton 17580w
Carrier 60000 btu/h air conditioner model number 42SD7C what type of refrigerant gas uses?
I tried to find something but its endless. Actually should find the info on the outdoor unit. What's outdoor unit model number?
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Carrier 42sd7c outdoor kilowatt ?
What are you wanting to know? Kilowatt is a measurement of electrical energy.
My acer projector flickers after 10 minutes and very hot air comes out from its vents, making it difficult to stand near it and it also show vertical lines.
the projector flickers after 10 minutes ,it seems that the lamp ballast is failing
shows with vertical lines, it seems that the LCD panels are failing or the panels cable not be tightly plugged (panel-cable plugs into the mother board)
We supply original projector lamp,bulb,parts,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
I dont have the disk for my web cam GE 98090 how can i get the driver ?
It says that it doesn't need a driver since it follows a universal driver included in windows. GE Perfect Image Webcam (1.3 Mega Pixels) Our Products: GE Computer Accessories > GE Webcams 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg1.jpg GE Perfect Image Webcam (1.3 Mega Pixels) 98090webg2.jpg GE Perfect Image Webcam (1.3 Mega Pixels) (Click to see larger image and other views) hs.align = 'center'; hs.transitions = ['expand', 'crossfade']; hs.outlineType = 'rounded-white'; hs.fadeInOut = true; hs.dimmingOpacity = 0.3; //hs.numberPosition = 'caption'; if (hs.addSlideshow) hs.addSlideshow({ slideshowGroup: 'slides', interval: 3500, repeat: true, useControls: true, fixedControls: false, overlayOptions: { opacity: .75, position: 'top center', hideOnMouseOut: true } }); function pcf_initEnhancement(ele,img) { if (document.getElementById('1')==null) { hs.expand(ele, { src: img, minWidth: 250, minHeight: 250 }); } else { document.getElementById('1').onclick(); } } SKU: 98090 Capture clear videos and sharp images with the GE Perfect Image Webcam. More details... Price: $54.99
icoaddtowishlist.gif icotellafriend.gif addthis_pub = 'jascoproducts'; addthis_brand = 'Jasco Products'; addthis_options = 'favorites, digg, delicious, myspace, facebook, google, live, furl, reddit, twitter, ask, technorati, stumbleupon, more'; icobookmarkshare.gif Product Details Capture clear videos and images photos with the GE Perfect Image Webcam. Capture high quality hands-free audio and broadcast through the built-in microphone. The stand can easily be adjusted to your desktop or clipped to your laptop or monitor. Complete with ArcSoft® VideoImpression™ and PhotoImpression™ editing software to capture, edit and customize images and videos.
Features:
  • Built-in microphone
  • Snap shot button - Easy to use for great still photos
  • Hassle free focus - Ensures crystal clear videos with adjustable focus ring
  • ArcSoft® Editing Software (Included)
  • Adjustable stand - Steady base ensures stable videos
  • Compact size - Provides convenience and portability, perfect for travel and laptop use
System Specifications:
  • Sensor: CMOS with 1.3 MP
  • Resolution: up to 1280x1024
  • Video frame rate: 30 frames per second
  • Color depth: 24 Bits, RGB True Color
  • Focus range: 10 cm -- infinite.
System Requirements:
  • Computer with USB port
  • 350 MHz recommended
  • 64 MB recommended
  • Windows® XP SP2 or Vista
  • 100 MB free hard drive space
  • 16 bit video display or higher
  • CD-ROM Drive
  • Universal Video Class no drivers
Price for acer x1161 model dsv0817 lamp
Street Price (USD) : $436 MSRP (USD) : $499 Brightness (Lumens) : 2500 ANSI Eco-Mode (Lumens): 2000 ANSI Contrast (Full On/Off) : 4000:1 Variable Iris: No Audible Noise: 30.0 dB Eco-Mode: 26.0 dB Weight: 2.2 kg Size (cm) (HxWxD) : 8 x 27 x 19 Std. Lens: Focus: Manual Zoom: Manual, 1.10:1 Throw Dist (m) : calculator.gif 1.5 - 12.0 Image Size (cm) : 86 - 770 Optional Lenses: No Digital Zoom: Yes Digital Keystone: Vertical Lens Shift: No Warranty: 1 Year Performance: H-Sync Range: 30.0 - 100.0kHz V-Sync Range: 50 - 85Hz
Where is my iat sensor on a 2005 ford focus zx4 2.0 duratech engine
IAT sensor stands for Idle Air Temperature
Try this website to download a free manual
Trouble trees are listed for all makes in the manuals for dianogstics
http://ezinearticles.com/?Find-the-Free-Auto-Repair-Manual-You-Need-Online&id=92717
1helpful
I HAVE A WEATHERKING MODLE WAKA-037JAZ OUTSIDE AC UNIT WITH SPLIT GAS FURNACE-WHAT TON IS THIS UNIT
It appears you may have a 5ton unit, if your house is over
2000sq. feet then Im guessing that 60 thats appears in
the model number is equal to 5ton. 12,000 btus per ton
of cooling
I need a stand for an Emerson tv model # LD200EMB. I do not want to mount it on the wall
Wal-Mart has a huge selection of TV stands at a very low price. They even have one that has a stand with an attached bracket that goes up vertically with a built in bracket to mount your tv to the stand
Top Carrier Heating & Cooling Experts
Jay Finke
Jay Finke
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
