Hi well NO I don't think that this unit has any other audio outputs? or "Monitor" as they are called, simply check the rear of the unit and the manual and see if there is any external outputs or "Monitor" Audio out, if there is it will be via Red & White RCA Jacks, these can be used to output to speakers or surround sound decoder. However this shouldn't be a problem as if you simply want to use this output, just obtain a Optical to standard audio output converter, and then you will be able to use this output in the regular way. And hook up to speakers or surround sound decoders as well. If you son;t have a manual, i suggest it will be a good idea to obtain one, approach the manufacturer or go to the website and look for one all info about the set will be in there.
