Jenn-Air JJW8230D Electric Double Oven Logo
Anonymous Posted on Oct 16, 2011
JJW8230DDB Jenn Air double oven. Black. Digital display. The only buttons working on the display are the Cancel buttons. Display still shows time, but I can not set the time (the clock button does not work either). I can not turn the oven on. I can not turn the oven lights on by the buttons on the control panel - however, those lights do come on when the oven doors are opened. Thank you.
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Oct 18, 2011
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620717
Points
5972
When buttons are not working most of the time it is due to a short in the touch pad or the electronic control in a unit you would have to call for service if you did not know how to use a multimeter to perform ohms and continuity testing and measureing of both pieces. Usually though due to the button not working most of the time it is the touch pad though. If you have any further questions message me back Thanks again
Rick
1 Related Answer
706Cajun
706Cajun
  • 34 Answers
  • Posted on Apr 25, 2009
SOURCE: Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
1helpful
Some touchpad buttons don't work but some do. Cancel button for bottom oven doesn't work. Have to flip breaker to turn off. CLock works
Jenn-Air WW30430P Oven User Manual - ManualsOnline.com
fitness.manualsonline.com > ... > Jenn-Air Oven
Free kitchen appliance user manuals, instructions, and product support information. Find owners guides and pdf support documentation for blenders, coffee ..
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
4helpful
3answers
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
1helpful
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
Jenn air oven
7helpful
4answers
Oven digital lighted display is dim
I replaced the C3 capacitor on the circuit board and works fine. This was mentioned in a prior post and took 5 minutes and was under $5.00 for the part.
6helpful
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
[email protected]
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
