Patio Heaters Logo
greg Posted on Sep 19, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have 2 sunjoy G-PH001PSS, when attached to the propoane tank, th unit does not light. I do not hear any gas whe turn the control knob to the on position. When i remove the gas line from the heater the gas will come out of the line as if the unit is not accepting the gas. Just filling the line but not ging into the heater. Both uniots arre doing the same thing.
  • 1 more comment
  • cramsey548 Mar 11, 2018
    There is a safety tip over switch on mine that went bad. Mine was stored horizontal for the warm season and this switch stuck. The switch has a copper ball in it that has to be upright to touch 2 internal conductors for the thermocouple. Ball stuck resulting in never getting a GO signal from the thermocouple. Follow your wires from the gas valve to the thermocouple and see if there is a little black box between them.
  • aamir
    aamir Mar 19, 2018
  • Anonymous Jul 12, 2018
    ust filling the line but not ging into the heater. Both uniots arre doing the same thing.People are having issues finding the login page after the new update, but has it changed? Here is how to find it.https://msnhhotmail.blogspot.com/
cramsey548
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Mar 11, 2018
cramsey548
Expert
Level 2:
Novelist:
Answers
127
Questions
0
Helped
69342
Points
383
deton8 von Splosion
Level 3:
  • Master 3,342 Answers
  • Posted on Nov 21, 2017
deton8 von Splosion
Master
Level 3:
Answers
3342
Questions
6
Helped
928539
Points
54123
Greg...
The lighting PROCESS involves HOLDING that
"PRESS MODE" for QUITE a (long) WHILE...
To clear the AIR out of your fuel line...
I have seen ... Up to 5 minutes
although I believe that is excessive)...
It is MOST LIKELY your troubles are procedural.
(READ the manuals)
ELSE
Blue Rhino
is the place to START ... or SEARCH
locally on the internet...
Try (they have manuals here... also)
Blue Rhino Outdoor Gas Heaters
Hope this helps
Carnac the Magnificent
1 Related Answer
Anonymous
  • 20 Answers
  • Posted on Oct 15, 2010
SOURCE: I have a Sunjoy G-PH001PSS that will not stay lit.
Either the burner tube is resrticted or the thermo-coupler is not working. Try cleaning the burner tube.
Sahara big burn patio heater
From the Troubleshooting Guide - Check the Obvious Turn on the gas and listen at the burner to see if you can hear the gas arriving.
If the patio heater has an electronic ignition system make sure that there is a spark. If there is a spark but the heater will not light up, try using a lighter or burning spill to light the gas. Be ready for a flash over if you have been trying to light the gas for a while-there might be a small cloud of gas near the burner.
Start at the Bottom The most likely reason that a gas heater will not work is that there is no gas. Take out the empty gas cylinder and replace it with a full one. Often you will feel that there is still gas in an empty cylinder but there is not enough to create the pressure needed to drive the gas burner. An empty cylinder will feel light.
Check the Gas Regulator The gas regulator is the connection of the gas cylinder to the gas pipe that takes the gas up to the burner. Some regulators have a flip switch that prevents the valve in the top of the cylinder from being depressed-effectively an "off" switch. If there is such a switch, make sure that it is in the "on" position.
Check the Gas Pipe Although it is most unlikely that the gas pipe can get blocked, remove the gas pipe from the regulator and from the gas inlet at the top of the heater. This pipe is pressure fitted and held in place by pipe clips. Blow air through the pipe to ensure that it is clear.
Check the Burner The burner will be a very simple assembly. Take each part off in turn and check for any blockages. Also check that the burner apertures are set correctly. Beneath each burner is a small chamber in which air and gas are mixed. Make sure that the gas and air inlets are clear.
If Your Heater has a Pilot Light If your heater has a pilot light, there is the possibility that the thermo couple has failed. The thermo couple is usually shaped like an inverted "v" and sits in the flame of the pilot light. The temperature acts on the thermocouple to keep the gas supply to the burner open. A good indication that the thermocouple has broken down is that the pilot light goes out when you try to turn the heater on. Thermo couples are readily available patio heater parts and usually available from stock.
If you have carried out all the checks and the heater will still not light, you can repeat all the checks more slowly and carefully or take your heater to a specialist for a service.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Pilot light bright yellow
Need to clean or replace it,supply tanks is empty, low pressure,bad regulator, not enough air supply etc. Kinked supply lines.?
Lava heater won't light
Try using a match, sometimes spark is not hot enough. be carefulle.
My propane outdoor heater lights and generates heat on low but when i turn control to high the flame and heat do not increase
The troubleshooting manual says low fuel, low fuel and cold weather and kinked supply line. Beyond this I would need to know if something happened to the unit like it fell over or was taken apart. Best, Joe 1_31_2014_3_36_44_pm.png
1helpful
No Flame
It could be dirty nozzle or dirty line
Unscrew every thing in the nozzle and control valve section and clean gas line and reinstall and try it
2answers
My pro temp dual propane burner heater will light but won't stay lit
Either the temperature probe (at the pilot light) that signals the gas valve to open is defective or the gas valve is.
I followed the instructions to a T. I turned my iHeater on using the--O switch located on the back. I adjusted the desired room temperature to 74 degrees. I adjusted the room size to Large. The iHeater...
I would read the customer reviews on this product , looks like nearly 70% of consumers are less than happy with this unit.
1500 watts is the units peak output, and drops to around 600 as it warms up. My hair blower puts out more power.
1500 watts is LESS than the output of a small element on your stove top. The real measure of heat is not watts, its BTUs and btus from gas are much cheaper than they are from electricity.
Top Patio Heaters Experts
deton8 von Splosion
ADMIN Andrew
ADMIN Andrew
CJ Rock
CJ Rock
Are you a Patio Heater Expert? Answer questions, earn points and help others
