Cannot factory reset DLink DCS-G900
shared by 6 users
posted by mikev80 on Sep 22, 2008
I cannot access this camera. I have tried factory resetting it. The power LED is solid red and the LAN always blink green. I have pushed the reset button. I have push the reset button and held for 30 seconds. Still no luck. I am trying IP: 192.168.0.20. Can I salvage this camera?
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Posted by larry323 on Dec 02, 2008
My camera worked for a while, then developed same symptoms - solid red and blinking green light.  I don't think the solution shown applies until you can get a solid green connectivity light.  As stated, reset button has no affect.
Posted by Schlyguy on Nov 26, 2008
I have the same problem. The green LED is blinking in a sequence, one blink, pause, 15 blinks, repeat.
Posted by feco76 on Oct 29, 2008
I have the same problem. Anyone found a solution for it?
Thanks
Posted by Guest on Oct 27, 2008
Same problem exactly
Posted by flneon82 on Sep 28, 2008
Same issue. Hitting the RESET button seems to have no effect on this device and the green light continues blinking and I haven't been able to access it at all to configure it. Not sure what I'll have to do.
Solution #1
posted on Nov 29, 2008
Not Rated (0)
rickhuck
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
i had the same problem and it was frustrating at first. You have to access your router and find the start ip address and the range and make sure dhcp is enabled. then plug the camera into one of the lan ports using the cable provided and plug the other end into the camera. then refresh the list of wireless clients in the router. Also if using a pre n router make sure that the broadcast is not mixed and is set to g mode. Only a g router will work or a router with g set to broadcast. i couldn't get the camera to work until i changed this setting. Anyways getting back to what i was talking about. When you see the list of clients you will see the camera listed on the client list. Write down the ip address example (192.168.1.108) and then on the computer (make sure you have another cable plugged into another lan port on the router and plugged into your computer) go into the dlink setup wizard. Press the search button the camera will appear on the list. Then click on the wizard and wait. It will say that the settings do not match there is an ip conflict or something to that matter do you want to change the settings click change settings and put the ip that the router configured. subnet mask is 255.255.255.0 and put the default gateway of the router which is usually 192.168.0.1 on most dlink routers but on the linksys i was using it was 192.168.1.1. After changing these settings it will let you into the camera configuration and after that you can unplug the cable and wait a minute or two. the green light should start blinking showing that the camera is connected to the router. Bingo your all done your camera is back to normal wireless function. You might have to unplug and reset the camera. If you have more than one camera make sure you unplug all the other camera's before configuring the first one. This will prevent any ip conflcts. Hope this helps you.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Cannot factory reset DLink DCS-G900:
I don't want to Accept this solution
Can you Help with these Web Cameras problems?
Web Cameras
sir please tell me how rigster to yohoo and password and...
Web Cameras
sir have try very much but i could not make my id and...
Web Cameras
I downloaded your programs to fix the problem loading my...
Web Cameras
girlfriend
Web Cameras
lost cd need drivers for my webcam
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Top Repair Providers for
Computers & Laptops
(412) 715-4340
We will fix all d-link or linklsys wireless...
ATCS Incorporated
(888) 430-9744
Computer Repair Over The...
OverNetUSA
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
X
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
