iRiver H340 MP3 Player Logo
Anonymous Posted on Oct 16, 2011
Iriver format problem - iRiver H340 MP3 Player
"file not supported" error after transferring a
Dude ,i'm having the same problem.my iriver E150 8 GB is also not playing any video.Anyone ,pleeease help
tip
Iriver Story HD vs Kindle
<br /> <a></a> <span><span><span>The Kindle 3 was released by Amazon in 2010. It is available in two colors, graphite or white. iriver Story HD becomes first Google eBooks-integrated e-reader, developed by Google and iriver, which is similar to Kindle, but the buttons are copper-colored. Here we compared iriver Story HD vs Kindle from multiple specs.</span></span></span> <br /> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Supported Formats</span></span></span> <span><span><span>Kindle supports eBook formats: AZW, TXT, MOBI and PRC.</span></span></span> <span><span><span>iriver Story HD supports: PDF, EPUB, TXT, DOC, PPT, XLS, HWP, DJVU,GB2.</span></span></span> <span><span><span>Note: sometimes conversion is need between different formats, </span></span></span><a href="http://www.drm-remove.com/resource/free-drm-remover.html"><span><span><span><span>drm free</span></span></span></span></a><span><span><span> is needed also. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>So according to the differences between iriver Story HD and Kindle,did you make a decision to buy which? </span></span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Physical Features</span></span></span> <span><span><span>The Kindle 3 weighs 8.7 ounces, and is 7.5 by 4.8 by 0.3 inches in. It has a 6-inch screen with 600 by 800 pixel resolution using Pearl E Inktechnology. It uses 4 GB of flash memory for storage.</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>The new iRiver eReader also boast a 6 inch XGA E Ink display with768&times;1024 pixels of resolution for a readable experience, 2GB of internalmemory, a 38 QWERTY keyboard with way controller for easy searching, USB 2.0port, wiFi and Lithium Polymer 1800 mAH battery provide read up to 140.000pages. In term of , the Google iRiver Story HD eReader measure in 128 x 9 x204 mm with weight 207 grams. (Related: </span></span></span><a href="http://www.drm-remove.com/resource/kindle-drm-remover.html"><span><span><span><span>remove kindle drm</span></span></span></span></a><span><span><span> , </span></span></span><a href="http://www.drm-remove.com/resource/remove-nook-drm-removal.html"><span><span><span><span>remove nook drm</span></span></span></span></a><span><span><span> )</span></span></span> <span></span> <span></span> <span><span><span>iriver Story HD vs Kindle: Display</span></span></span> <span><span><span>As you can see, whilst the devices look virtually identical in and shape, there is a slight difference in the actual displayed picture. Therepresentative that brought the piece of hardware also said that this iriverStory HD device will be the fastest refreshing e-reader on in the market currently.</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Price</span></span></span> <span><span><span>The iriver Story HD will cost $139, which is the same price as theKindle or the Nook.</span></span></span> <span><span></span></span> <span><span><span><span><br /></span></span></span></span> <span><span><span>iriver Story HD vs Kindle: Connection</span></span></span> <span><span><span>The Kindle 3 can be connected to your computer using its USB datacable or using WiFi through your home network. For purchasing books fromAmazon, the Kindle 3 uses the same 3G wireless networks. It takes less than aminute to download a book using 3G Wireless, with no cost to the user forwireless access. (related software: </span></span></span><a href="http://www.drm-remove.com/resource/remove-drm-from-ebook.html"><span><span><span><span>drm ebook removal</span></span></span></span></a><span><span><span> )</span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>There's also WiFi - along with Easy Wi-Fi Network support for easierlogins at open hotspots, which means you can buy Google eBooks over Wi-Fi. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>iriver Story HD vs Kindle: Supported Formats</span></span></span> <span><span><span>Kindle supports eBook formats: AZW, TXT, MOBI and PRC.</span></span></span> <span><span><span>iriver Story HD supports: PDF, EPUB, TXT, DOC, PPT, XLS, HWP, DJVU,GB2.</span></span></span> <span><span><span>Note: sometimes conversion is need between different formats, </span></span></span><a href="http://www.drm-remove.com/resource/free-drm-remover.html"><span><span><span><span>drm free</span></span></span></span></a><span><span><span> is needed also. </span></span></span> <span></span> <span><span><span><br /></span></span></span> <span><span><span>So according to the differences between iriver Story HD and Kindle,did you make a decision to buy which? </span></span></span>
on Aug 01, 2011 • Computers & Internet
IRiver H320 won't boot...
format is exactly what you have to do...but this how you do this...plug iriver
to pc..goto my computer see the iriver...click on and copy all software only (hidden also) from iriver and save to temp folder on pc...now format the iriver.......okay....now copy from that temp folder (the iriver software) back to the iriver.....put you audio/video on its like new again...
I have an Iriver e100 when i put any track(mp3 file format) when im tryng to play it it says HDS error, Clear DRM HDS
You can first format your iriver mp3 total. then reload your mp3 formated songs from virus less computer. then i think your mp3 player become ok
Iriver X20
can you connect it to your computer?
if so then format it then run iriver plus 3
plug it into the computer
then go to tools>Portable Device>Disk Initialization
if you cannot connect your x20 to your computer
there is a tutorial on the iriver support page saying you can format it by,
holding down menu butting and turning it on
but that didnt work for me..
otherwise, its stuffed..
if its stuffed, dont throw it away, ill buy it off you..
contact me if your interested, [email protected]
I was trying to turn off my iriver, but now it is frozen in the shutdown screen. Prior to that I had it connected to the computer, with the iriver software running. It tried to read the iriver, got stuck...
connect Iriver back to PC...go to my computer open Iriver and copy the software only (hidden files too) you do have your files on the pc and or the cd's.....because you are about to format the Iriver (this will erase everything) open a temp folder to hold software on PC.......copy/paste software to .......now go back to my computer right click to format the Iriver . once format is complete copy/paste the software back from PC to Iriver...now copy/paste all your mp3 files from PC/cds to Iriver.......its like new all over again
Iriver D5 korean
iriver has problems with its video playback...
only certain formats can be played...
the iriver should have come with a converter on the provided program so just use that to convert the files to the format you need.
if that doesnt work try and get winavi converter.
Iriver X20 database full
does the message stop you from using the iriver?
if it doesn't then there's a format function on the iriver in the settings menu...
if it does then there may be a problem with the usb connection...
either the iriver isnt responding or the computer can't read it!
for the user below there is most likely a format will fix it...
Putiing music on the iriver h340
iRiver has a special DRM signature, and only recognizes certain file formats. iTunes will ont work with the iRiver,for instance. Here are the formats recognized:
MP3 file
: WMA file
: OGG file
: ASF file
: IRM file
What is IRM (iRiver Rights Management)?
The IRM is digital copyright information file designed by iRiver
Limited. The IRM technology protects copyright and property from
unauthorized usage of digital contents provided through iRiver
Limited.
Use the proprietary software found on the IRiver website to transfer songs. If they still won't play, run the songs through Media Monkey or another Mp3 Converter to make them playable.
-Tha Mp3 Doctor
1helpful
3answers
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Top iRiver Audio Players & Recorders Experts
SmartAviator
SmartAviator
Mohammad Abumuailek
Mohammad Abumuailek
ExpressFiX
ExpressFiX
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
