Re: RCA D52W20B F013C30N4 when turned on the image it...
Does the set continue to play normal except for the green being too pronounced ? Or does the set turn bright green with curved lines then the set shuts down? Let me know and I will assist you.
Chances are its the Green CRT drive board which is causing the issue . I would try replacing the green CRT drive oard you canget one from www.tvrepairworld.comChances are its the Green CRT drive board which is causing the issue . I would try replacing the green CRT drive oard you canget one from www.tvrepairworld.com
You can't post conmments that contain an email address.
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
yes u may have a problem with the power supply , bad capacitor on the power supply 2200uf at 25volts , thats the only cap with this value , it's right on the power supply
The repair kit called the CP150, CP120 and CP114 repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the parts and instructions.
Replace the CP150, CP120 and CP114 capacitors. You can get the RCA repair Kit by that same name from www.tvrepairworld.com which also has the CD with instructions.
The CP150, CP114 and CP120 repair kit available from www.tvrepairworld.com should repair that issue. The kit contains the parts and the CD with instructions. Its 24.95
most likely ifthe convergence option is missing from the on screen menu you will need to replace CL230, DL231, and FL231 you can get those parts with free instructions at the following link, http://servicemanuals.vstore.ca/
my first instinct when i hear this at the shop is a shorted horizontal output transistor. and with that usally a flyback also. If you know any electronics you can replace. Replacing these components are not for a novice. i would first check the transistor to be sure
Look on Deflection board see if capacitor 150 is open on top 2200uf 16 if so replace it and the two near by it 220uf 35volts other wise order new deflection board cost verys 125.00
Caps are Green with gold writing on them.
