If your Acer laptop internal hard disk is not detected, maybe it has been turned off in System Setup. It is also known as the System BIOS or sometimes CMOS Setup. Therefore, you should enable it in System Setup. ... Besides, you can try to change the disk controller setting from AHCI to IDE in BIOS Setup.
Solved:Acer Laptop Hard Drive Not Detected
Repair laptop hard drive is not detected
Solution 1
1. Open the hard drive cover (remove two screws)
2. Remove the hard drive screws, then slide the hard drive (see the arrows)
3. Wait 15 minutes, then plug the hard drive
4. Turn on the laptop.
Solution 2
1. Remove the hard drive
2. Clean the gold layer with a pencil eraser
3. Plug the hard drive, then turn on your laptop
Solution 3
2. Plug jumper on the hard drive
3. Plug the hard drive, taspire one can not detect hard drive - 10_15_2011_12_17_58_pm.jpgpan>laptop
Solution 4
1. Remove the hard drive, plug the external cable.
2. Connect the hard drive to another computer, with USB connection
3. If the hard drive can be detected, eject the hard drive
4. Plug the hard drive to the laptop, then turn on
Intended to make the hard drive can woaspire one can not detect hard drive - 10_15_2011_12_27_05_pm.jpgspan> help of another computer
Solution 5
1. Remove the laptop hard drive
2. Plug the laptop hard drive to my PC.
SATA1 - PC hard drive
SATA2 - Laptop hard drive
3. Boot the computer from a PC hard drive
The purpose of using a PC computeaspire one can not detect hard drive - 10_15_2011_12_32_25_pm.jpg/span> as drivers of the laptop hard drive.
I hope this information helps. Thank you for using FixYa!
ishadi post uses wrong PC, for sure.
the AO5xx series has no such jumper nor any needs like that ,
OP we can test your HDD in any PC made
ask and is way more simple for 2010 PC
unlike ishadi posters early 2000's PC.
we can in fact test any 2010 PC year, HDD easy
ask.
Hard drive can be detect any time. But if the hard drive crushed then data would be lost any time. I also faced the same problem and searching for data recovery service center. Because expert technician would be solve such types of problem.
no PC model told ! for 33 + sub-model numbers
guess at AOD521 made 2010 wild but wise answer.
W7 loaded then.
1: batteries bad, all, RTC too.
2: HDD is bad. we test it using TOOLS ask,
3: HDD only OS corrupted, reload OS.
#3 is mostly due to Virus infections to W7 easy.
Laser printers need even more preventive maintenance than other types of printers. Usually a laser printer prints more pages a minute and has more moving components. The maintenance process involves far more detailed inspection of ozone filters, static remover teeth and fuser units.
Plotter Repair near me | HP Plotter Repair Services | Designjet Printer Repair | Plotter Repairs Service | HP Plotter Repair Center | Canon Large Format Plotters Repair | Oce Plotters Repair | Xerox Copiers Repair | Wide Format Plotter Repair
philips off topic spamming like mad.
go away.
the TOPIC is dead PC with DEAD CMOS RTC battery and has nothing to do with any printer.
Serving small to medium businesses & Non-Profits in Northern VA, Washington DC & Maryland.
what good is that. to the world. zero.
