I have the same machine, [pull plug wire for safety] tip machine on it's side, next remove blade, now remove all the plastic shields that are above blade right to the deck bottom. You wont believe the grass build up around blade shaft. On this machine as you select your speed the pulley travels on shaft, but with the grass build up the pulley can't move. I've done mine twice now in the last 4 years. You'll need around 3 hours, good luck it's not that bad.
