Re: I have a ladies wave, two tone, dia dial. Can I buy a...
I can pull out the crown 1 step to adjust the date and another step to adjust the time but not completely. I looks also like e screw but is that really the case? Do I have to use a lot of force to get the crown out? Jan
I would suggest taking your watch in to a local jeweller. They should be able to replace the battery for a few pounds or give you an opinion on other options. A Google search should find several in your area.
You can try a polishing cloth to see if this removes the discoloration, or very gently brush it with a toothbrush and mild soap ( very little water) if this does not help you will need to send the watch back to Bulova to their service center. 1-800-228-5682 is the Bulova service center phone number, call them for further instructions. Sometimes the discoloration is caused by certain chemicals found in lotions, soaps and cleaners. Hope this helps! thank you!
Thank you for visiting FIXYA.<br />
The best place to get a Skagen band is direct from them. I am forwarding you a link to help you out! Best regards!!<br />
<br />
<a href="http://www.skagen.com/service/orderWatchBandParts.fx">http://www.skagen.com/service/orderWatchBandParts.fx</a>
The back will need to be romoved, but in doing so yourself, you will VOID your warranty, and since this is an expensive watch, I highly recommend that you send it in.
You can find all this information here:
to change the batt on an ebel womans watch i simple. 1 take out screws from bezel. 2 lift off , make sure to keep rubber gasket in place. 3 pull out stem to the set position. 4 be very carefull not to bend / touch hands. 5 turn case upside down, and you will see the opp side from the winder drop out slitely. with your fingernail pull downwards gently on works, then when you have it out a little on that side, turn it back over. and continue to lifft up gently, 5 as you do so, start to rowtate the works counter clockwise. the stem is made to .bend / swivel and the works will turn upside down and lay back into the case. to protect the face while installing the batt. 6 when done gently lift the same way but rowtate clockwise. but make sure you grab sides of works and not the face. ( the hands are very delicate) 7 take the batt to a jeweler to replace you will never find a batt with the same number ( ebel made sure of that ) they want you to pay 140.00 to 240.00 for them to do it. but a jeweler can match it. now that said, once you take the bezel off, your ebel warenty is void. so 140 -240 or $5.00 your choice i have had meny watches over the years all with rubber gaskets and have replaced batts is some five times and the gasket are still fine. and a batt will last 3 to four years. five in 15 years could cost you $ 1020.00 in the long run. hope that answers your question.
They Are not settable., They just are there to replicate what the genuine looks like. The bezel is a tachamyter it is a stop watch function of the watch, but most likely your watch does not have stop watch "chrono" functionality.
