Question about Krups FLF2 Cordless Electric Kettle
Srainer inside my Krups jug kettle has split. Can anyone tell me wher to get a replacement? I've got 2 of these kettles and have been very pleased with them both until now. Thanks.
SOURCE:
  • 22 Answers
SOURCE: kettle gets heavy white residue on inside after a couple uses. we do not ever let it stand with water inside.
Cheapest fix is to use white vinegar to disolve the building up of limestone hardness in your water. I am certain that you find it difficult to get soap to lather well, you have a bathtub ring every time you take a bath, your towels and sheets are stiff and scratchy and your lower legs itch terribly especially in the winter. You have very hard water and you need a water softener. Find a Certified Water Specialist in your Yellow Pages.
Posted on May 25, 2009
SOURCE: Chefs choice electric kettle 677 works sometimes
I have the same problem and I tried to open the base to clean the contact points but found that it is molded into one piece and would have to be cut open and then glued shut when finished. I am about to pull out the file for the kettle contacts because its headed for landfill If I do nothing so I cant make it worse. I am going to file the contacts until itere a little shiny.
Posted on Oct 08, 2009
SOURCE: krups electric kettle leaks
You cannot fix it when they split like that.
Posted on Apr 01, 2010
Obertelli
  • 3006 Answers
SOURCE: krups kettle leaks at base of pot
Unfortunately it's unfixable. A few recent Philips models do it as well and it's worst in hard water areas. Basically the cause is that a tiny bit of water gets into the bottom seam each time the kettle is used and leaves a residue behind when it dries out. Over time, the residue builds up and forces the seam apart so the leak gets worse.
All you can realistically do is hope that it's still under warranty and demand that Krups replace it, preferably with a different model. If they won't then you may have to exert whichever consumer rights exist in your country, but one way or another you need to stop using your kettle (it's dangerous!) and replace it with another.
Posted on May 21, 2010
  • 9 Answers
SOURCE: When the kettle is switched on, the light comes on...
sounds like the element has died. If it's still under warranty, take it back. If it's not under warranty, contact an electrician or appliance repair person. Unless it's an expensive kettle though, it's probably not worthwhile fixing, as elements can sometimes be as expensive as a new kettle
Posted on May 23, 2010
Do you have a base for Morphy Richards jug kettle. no. 43161
we do not as we are not the manufacturer or a rep of said company .
Jul 04, 2016 | Morphy Richards Kitchen Appliances -...
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
Fuse box turned off when switch on the kettle
kettle defected check for short or to many plugs on servie line try another plug
Sep 02, 2012 | Russell Hobbs Kitchen Appliances - Others
My russel hobbs jug kettle is leaking very badly and it's not 2 years old yet
Why would anything else fail because the kettle seal has gone? They are generally ok aren't they?
Apr 26, 2012 | Kitchen Appliances - Others
Krups kettle leaks at base of pot
May 21, 2010 | Krups FLF2 Cordless Electric Kettle
Krups electric kettle leaks
Apr 01, 2010 | Krups Stainless Steel Electric Kettle...
Krups kettle explosion???
go to krupsusa.com customer service
Oct 11, 2008 | Krups 848-70 \ 848-42 Aqua Control...
Rust coloured spots on insie of kettle
We buy DeBruce Polish at debruce polish.com, this stuff really works.
Mar 19, 2008 | Sunbeam 3211-2 Electric Kettle
Krups FLF2 Cordless Electric Kettle Logo
54 people viewed this question
Top Krups Kitchen Appliances - Others Experts
mrtoolsel
Level 1 Expert
Mike
Irene Tulloch
Are you a Krups Kitchen Appliances - Other Expert? Answer questions, earn points and help others
