Question about Bunn VPS Coffee Maker
Can't figure out why when I plug in my bunn vps commercial coffee maker it immediately trips the circut breaker???
  • 3,053 Answers
There is a couple things can cause this to happen.
Number one make sure you have nothing else added recently on that circuit, where you have had your machine plugged in. If something was added on that circuit, something that is always running like a fridge, that could be overloading the circuit, sense coffee machines use a huge amount of power at start up. If your sure nothing of that sort has changed then next is:
Number two, make sure you have cleaned the machine, you know descaling and making sure there is no restrictions. If this is good, then next is:
Number three, it appears you can have a short. The heating element going bad in the coffee maker. If the thermostat or heating element is pulling more power boost then normal because its going bad or a short this will trip the breaker. What I would first do, is run yourself a extension cord from another outlet that for sure is not on same breaker. If that breaker blows, then you know for sure it is the machine that is causing this, then we are back to the heating element or thermostat on off regulator.
What i have done is located the manual on your machine, that besides gives you a lot of information, it also gives you trouble shooting tips and schematics of the parts and wiring diagram for you machine. Here is the link to copy and paste in your browser to download the manual.
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
Please if this helped you, rate my free solution and a pleasant testimony would be nice to help me and others on my efforts of helping you. Thanks So Much, Mike from Fixya.
Posted on Oct 14, 2011
  • 3 more comments
  • Doug Skaggs Oct 14, 2011
    Thanks, I will check this out next chance I get. I appreciate your help!
  • Doug Skaggs Oct 15, 2011
    Must have been the tank heater going out. Now it is no longer tripping the breaker but the element is not heating any longer and will not brew coffee. Thanks Mc1bean for your advice.
  • Mike Cairns
    Mike Cairns Oct 15, 2011
    Thank you so much for rating my help. I appreciate that. I try real hard to help a person as much as I can to solve there problem. I am a coffee drinker myself and nothing worse then your coffee machine not working. Thanks Again, Mike
  • Mike Cairns
    Yes , it appears that it was tripping as it was warning you it was going out. And sense now does not work at all, seems to be true. Please look in the manual I sent you, it shows those parts in detail from the trouble shooting section and even has wire schematics of how to replace those parts that went out, and where they are. HOWEVER as a Warning, it says all through the manual concerning those parts, that they recommend a professional when it comes to replacing those parts. That is up to you if you want to tackle this project yourself. NOW as a another option if you don't every town and state sense the coffee business is so huge, most likely in your area, if you look up major bean suppliers, like long bottom, k&f, Bridge Town, etc.,, most of them have a service shop to repair machines such as yours. Also I am pretty sure that Bunn, can refer you to a dealer that repairs in your area. To bad you were not in my local, area I could fix it for you in about 45 minutes or less. But good news is you have the manual, and at least know what is going on, and maybe get lucky and it will just be a short on the switch that controls the heating element. Look at manual, and maybe you can fiddle with it there first before you replace the whole element. But, please be careful to not cause more damage, and make sure machine is unplugged when ever your working on it. Mike
    Thanks. I have already taken the top off the tank and the element was in pieces. I ordered the part and when I get it replaced I will let you know how it does. Thanks again!
6ya staff
SOURCE:
Vapor lock when I pour water into the fill tray, won't flow into tank. Bunn VPS Commercial
Are you sure the water passage is no plugged? Lime will build up and actually close it off .
Feb 22, 2018 | Bunn Coffee Makers & Espresso Machines
My bunn vpr coffee maker is overflowing
Maybe this will help you, with information, trouble shooting and contact numbers.
BUNN VPS COFFEE MACHINE MANUAL
Also if you could rate this and some kind words would be great. Also here is my direct link to my pages of expertize that might help you. Visit me anytime at :
http://beta.fixya.com/users/mc1bean
Oct 15, 2011 | Bunn VPR Coffee Maker
Looking for an electrical schematic for a Bunn VPS
Sep 23, 2011 | Bunn VPS Coffee Maker
Burner is hot but coffee coming out is not
''Hello,
Thanks So Much, Mike '
Sep 21, 2011 | Bunn VPR Coffee Maker
Poured water into the Bunn Coffee Maker Reservour is not heating the water.
Aug 16, 2011 | Bunn VPR Coffee Maker
My bunn coffee maker stop heating the water and the warmer will not heat..what could have happen
Aug 14, 2011 | Bunn VPR Coffee Maker
The nurses use the Bunn VPR 2 burner coffee maker. They have succeeded in having horrible hard water residue all around the outside of the pour area. Vinegar doesn't seem to clean it off. What would...
This can be solved by running vinegar and water through unit and here is more information.
Jun 16, 2011 | Bunn VPR Coffee Maker
Water gets hot won't brew----help
Jun 08, 2011 | Bunn VPR Coffee Maker
We have a Bunn VPS 3 and we need to know how much water we should keep in it ?
You should keep the unit full of water all the time it's plugged in, as if it is low on water, the heating element will burn out. A Bunn VPS brewer holds about 2 -64 oz pots of water in it's resevoir.
Jan 21, 2009 | Bunn VPS Coffee Maker
Bunn VPS Coffee Maker Logo
587 people viewed this question
Top Bunn Coffee Makers & Espresso Machines Experts
Inky Fingers
Inky Fingers
Marvin
Marvin
littlechum55
Level 1 Expert
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
