This is the picture of the T'Con board in search I thinks. To buy it, enter into this site, and make an order.
www.ebay.com/itm/Norcent-LT...T-CON-Board...-/130557085004
You can get a T-con board at www.partstore.com
"You can get a T-con board at www.partstore.com"
No you can't.
norcent LT 3751 t con board AF235B00005
AF235B00005 is the power supply / PSU.
WHAT'S E247076 THERE NO STRIP OF PAPER WITH NUMBER ON THE ONLY ZV7UV1.000 HELP
This is the picture published for the T'Con board of Norcent LT3751. I've got this image by google search. The board will be there in your tV. OK.
The T-Con board in the picture you posted is from the Norcent LT-3222 - 32".
I can fix all brand of tv
Check out the website "shopjimmy". When you get there have your brand and model number, use it to find the main boards. They will show you all the boards available by name. I think this is a unique idea. I have done this, as I will know what I'm looking for when I open the back cover of the TV set I'm repairing. Thanks for asking me. and show all hands of support!
If you were to log on to the
manufacturer's web site, I think you will be pleasantly surprised as
usually one is able to download, by model number, Customer
Instruction Manuals, list
of Dealers for spare part supplies as required.
The information is normally free of
charge.
I hope this helps.
I'd need the part number from the original board to find one of those and it's probably going to be extremely difficult to obtain. They are usually printed on a barcode sticker on the board or on the board itself. I don't have and wont be able to get a service manual for this TV, so I have no part code list.
THAT DOESN'T LOOK LIKE ANYTHING IN MY TV THESE ARE THE NUMBERS IN SIDE FAZX7001019 3V
ZX7U V1.000
SNAXFD0636034978
AF235B000005
DA0ZX2MB6D1 THANKS
None of those are the part number for the T-Con board. You need to get this number/code from the actual T-Con board. Most likely on a white sticker. Searching for it using your TV model number gets no results anywhere, but this board is unlikely to be unique to your TV, so it should be easier to find (if available) with the correct part code. Sorry fella . . . no tickee, no laundry.
