Question about Samsung DLP HL-P5663W 56" TV
Sansung model 56 Inch hpl5663w first had a buzzing sound the tv repair man said it might be a color wheel but the tv played well except for the low buzzing sound . then one night the picture went black and the tv shut off the message i got was a blinking green lite that said Lamp. also below that another message said stand by temp in red I replaced the blub and housing but got the same messages. Can you help.
  • Samsung Master
  • 2,098 Answers
Hi Charles,
Sorry for the late reply, I'm offline upon purchasing my service.
You have said that you can hear a low buzzing sound before the unit gone to subsequent shutdown and the lamp blinks green(meaning that the unit try to turn on the lamp for consecutive attempts but not generally mean that the lamp itself is faulty.) and the temp led light come on.
As a matter of fact all the information you have mentioned linked to the symptoms you've encountered right now. A low buzzing sound might be caused by faulty FAN inside the unit that trigger the error code (blinking of the standby/temp led light) and turns off the unit automatically due to thermal protection circuit.
However, the technician might be true also that the buzzing sound came from the faulty color wheel. To confirm it, you have to verify where the buzzing sound came from. Color wheel is in front of the lamp assembly. Faulty color wheel can produce the same symptoms you've encountered right now but most of the time, it shows 3 blinking led light at the front panel (Timer, Lamp, standby/Temp).
I would advice you to open the back cover of your unit, fixed the lamp door safety switch with the tape to make it in closed position( if it is on open position the unit will not power up), and then turn on the unit and observe the fans if will spin or not, and check also where the buzzing sound came from before the unit gone to shutdown.
I've suspected that the fault came from the fan based on the led light flashes. Please let me know what you will discover after following the steps above to verify where the exact fault came from. Also, let me know the exact status of the led light at the front panel, (Timer, Lamp, standby/Temp ), which of them lit solid/blinking, it will help us to narrow the caused of the symptoms.
Jdvillanueva
Posted on Oct 14, 2011
  • 1 more comment
  • Charles Canino Oct 15, 2011
    I taped the lamp door cover spring down pluged the TV into the electric outlet I heard a click the TV went on after a few minutes the picture picture was OK for about 15 minutes then it got darker and the colors ran into each other for poor picture Quality also the only way I can turn the TV off is to pull out the plug from the outlet & to turn it on plug it back in the on & off button does work. any suggestions.
  • Jdvillanueva
    Jdvillanueva Oct 16, 2011
    The symptoms you've mentioned right now is an indication of faulty DMD board. If this board gone to malfunction, symptoms below will be encountered.
    - Poor picture quality, vertical lines on the picture, grainy pictures, abnormal color and other picture problem.
    - Video lock up either immediate or intermittent.
    - Sound OK, but no video and/or control funtions.
    - Unable to turn the unit off, or no control of functions. The unit needs to unplugged and plug back in to power up again.
    - Control to color wheel is not normal resulting to abnormal colors/picture and performance of the color wheel.
  • Jdvillanueva
    You need to replaced the DMD board (part no. BP96-00678A)
SOURCE:
I'm experiencing a loud buzzing (fan?) sound that just started recently while watching my HLP5674W. The picture is fine, but the sound of what may be a fan or something like that is very loud and will...
Loud sound would be coming from defective color wheel that is mounted i light engine, next to lamp housing. Replacement of color wheel is required expertise/ experience and professional will do that for you in correct and in safe manner.
Contact local tv repair shop to get color wheel replaced in tv.
Thanks.
Oct 19, 2010 | Samsung HLP5674W 56" Rear Projection...
I have a samsung dlp model hlr4667wax, when first turned on it makes a whistling noise then a buzzing noise any suggestions?
It could be you color wheel try to go bad, however when it does you will lose the picture. If you can repair or fix a computer you can change your color wheel if it goes. Cost Appox $100 you can search by your TV model #
Good Luck!
Oct 10, 2010 | Samsung DLP HL-P5663W 56" TV
Makes buzzing sound and no picture lamp?
Buzzing sound is the Color Wheel # BP96-00250A $83.25 Encompass Parts has them in stock 1-800-638-3328 and for Lamp Call FOX 1-800-227-5369 I got my Lamp off of E-Bay $85.00 I have the Same TV.
Dec 24, 2009 | Samsung HLR5667W 56" Rear Projection HDTV
Sansung DLP HL-P4674W Is making this loud humming noise and the oicture is now in black and white
sounds like a the color wheel blown. Call a local tv repair shop. Some Samsung models carry two different color wheels for same model depending on chassis version which can be seen only when the back is removed.
Dec 08, 2009 | Samsung DLP HL-P5663W 56" TV
My tv is making a loud buzzing noise
Bearings in color wheel going bad and needs to be replaced. Call a local tv repair shop on pricing and availability of color wheel for your model and chassis
number.
Dec 03, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung Model HLR4667WAX/XAA is making a buzzing sound
It is likely the color wheel motor making noise
Check this link
http://www.jangro.com/electronics/samsung-dlp-replace-color-wheel/
If it helps be sure to vote/rate me Thanks
Oct 06, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung DLPTV bad picture and buzzing sound
You color wheel blew a bearing. You need to replace the color wheel.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Samsung HL-R6167W DLP color problem/buzzing noise
My 3 yr old Samsung DLP has the same buzzing noise, had a tech out today and he said "color wheel". Thank goodness I purchased that expensive warranty, This is my 4th repair in 3 years.
Dec 24, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
108 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
