How to Align a Printer Cartridge for a Dell Photo AIO 926Printers capable of producing high quality graphics and photos, like the Dell Photo All-In-One 926 printer, must have their cartridges properly aligned for best results. Typically you only need to align your printer's ink cartridges immediately after replacement. However, if documents show signs of uneven lines the cartridges being out of alignment. After aligning the cartridges print a test page to check print Instructions 1 Load printer paper into the Dell Photo 926 printer 2 Click on the start menu icon, on your computer, with your left mouse button. Left click on "Control Panel." Left click on "Hardware" and then left click on "Printers and Devices." 3 Locate and double left click on the icon for the Dell Photo 926 printer. The printer control window will open. Double left click on the "Adjust Print Options" button. 4 Click on the "Services" tab in the printer's window menu bar. Double left click on the "Align Print Cartridges" button." Left click on "align." Wait for the "Parameter" page to print. 5 Compare the figures on printed parameter page to current settings in the "Align Print Cartridges" window that has popped up on the computer. If the figures on the printed page correspond to the figures displayed in the window the cartridges are in alignment. If the figures on the page do not correspond with the figures in the window you need to set new parameters. Enter the new figures from the printed parameter page into the fields on the align print cartridges window on the computer, as directed by the prompts. 6 Click "Done" or "Okay." Exit out of all menus. Print any document and check the text and or graphics for quality.
You can get solution for every problem to Dell products on www.pcasta.com.
Best answer!
electronics wholesale
SOURCE: HP photosmart 7150 - looks like it's printing - pages blank
Normal
0
Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off.
I'd do both and reinstall the CD software program that came with
the printer. When the software program asks you to connect the
printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
SOURCE: prints test page every time the printer is turned on
The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
Read the info on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01336397&cc=us&lc=en&dlc=en&product=1146336
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: Print Head Alignment test produces only a blank page.
Yes head probably clogged. You can try cleaning head multiple times, I think this is a pigment ink machine, so get only these carts for it
SOURCE: Lexmark X2580 won't print after cartridge refill
I know this is something that you may not want to hear... I used to work for Pitney Bowes fixing postage machines.. these machines have inkjet printers in them. If you use refills other words ink not from the manufacturer it will cause you problems. I know that it might work a few times without problems... but I have seen it first hand at Pitney Bowes... If you don't use the manufacters ink it will destroy your printers. In your case go back to using the Lexmark cartridge... see if that solves the problem. Which it very well could work off the Lexmark brand again. Printer manufactures do this on purpose you have to buy their ink! In any case good luck.
cdixon18
The Man Inside the Machine
SOURCE: Unable to print on printer Dell 926 -test page prints ok
Hope this help. Please
Rate My Response! Thanks!
PREM
