Question about Samsung RB2155SH Bottom Freezer Refrigerator
Top does not cool any longer-alarm keeps going off what can i do?alarm kept going off-tempature kept rising in the top unit remained the same temp in the freezer
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Posted on Apr 01, 2008
Anonymous
SOURCE: Samsung double door refrigerator/freezer is not
I just had (have?) this same problem. I called out the repair man and in the end he suggested that I buy a new fridge because of all the problems reported with my model (RS2555SL) on the internet. Anyway, after a while I heard what sounded like a fan trying to spin on the fridge side. I unplugged the unit, removed the inside back panel on the fridge side. The entire coils and the fan had iced over. I removed all the ice, plugged the unit back in and it is now working. I will still replace this unit because I probably only corrected the symptom but the problem remains.
Posted on Jun 21, 2009
vetteman3002
Rodney Clark
  • 2299 Answers
SOURCE: RB1955VQ Frig. with bottom freezer
Is the compressor running constantly? Or is the compressor not running? Please explain. Thanks!
Posted on Mar 10, 2011
How bleed coolant line on a 2005 chevy avalanche
You need to start this when it's cool not hot take your radiator cap off start the engine start adding water into the radiator keep checking it with your finger and keep adding when the water turns warm to the touch keep adding water if it's taking it and squeeze your upper radiator hose continuously to burp out the air keep adding water try that and see how it works
Oct 03, 2017 | Chevrolet Avalanche Cars & Trucks
My fan never shuts off.
Have you replaced your thermostat. Sounds like its temp is a little high. Try a 180 degree stat. This might Will probably sole the problem. Cheap fix too
Aug 18, 2012 | Pontiac Cars & Trucks
I have a Prestige fridge/freezer model prt325ffcs, 18months old, and the problem is that the freezer compartment is not remaining cold , the super freeze function works reducing the temp. to -25 , but as...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Refrigerators
RF214LXTS 0 I have a whirlpool stove, have power on both incoming legs. the top works fine, but the bake and broil elements in the oven dont work. the saftey fuse on the back seems to ohm out good as...
The way power typically is supplied to the bake/broil elements is that directly off the terminal block 120volts ac is supplied directly to the elements at all times and when the touch pad is pushed a relay on the clock/eoc (electronic oven control) will close and supply 120vac so the element has 240vac to heat. you should be able to see the wire coming directly off the terminal block where the cord from the house wireing connects to,going directly to the elements and as stated above theother 120 vac from the relay to the elements (their is 2 relays,one for bake and one for broil)
As far as testing the oven sensor(temp probe) at room temp the ohms reading should be 1060-1100 ohms and as the tempature rise the ohms rise so to test it verify is 1060-1100 at room temp then heating it usinga blow dryer,match or cigarette lighter and the ohms should rise as it gets hotter and drop when its cooling
Good luck,i hope this helps and if it does help please give me 4 thumbs up
Gene
Jul 27, 2011 | Whirlpool Ovens
Lemair wine fridge not holding temp.sounds to be going ok but not cooling.temp keeps rising????.will not hold temp you press on digital readout.thks in advance
Hi.
If the unit looks like it is working regularly, but it does not keep the regular 14C temperature, then the problem is either defrost system or need for gas recharge.
Disconnect power and perform a full defrost leaving the unit off overnight. If the problem disappear, then the fault was the defrost system in the unit. If the problem comes back in a couple of days, then the defrost thermostat must be replaced.
If the problem comes back immediately after defrost, then you need a gas recharge. When problem is the compressor you hear clicking and humming, or motor does not start at all.
If you need recharge, parts or repair contact Lemair. Here their website. Contact page link is at the top.
Regards.
Ginko
May 17, 2011 | Refrigerators
Oven temp not correct
One thing you should know about a gas oven is that they do not keep a constant tempature like an electric oven does. So going by a tempature gauge in the oven can fool you. The way a gas oven works is by "average" tempature. In other words if you take the highest and lowest tempature readings and average them out you will get the actual tempature. For example let's say that you set the oven to 350. Well first it will take about 10 to 15 minutes for the oven to properly pre-heat. Once it is preheated you can listen to the gas burner and watch a tempature gauge(flook meter is best). When the gas burner shuts off the oven tempature will continue to rise. When the oven tempature stops rising then you will take that reading. Then wait for the oven burner to come back on again and watch the tempature gauge. When the tempature gets to it's lowest point and stops then take that reading. Do this several times and then take all the tempature readings and add them together then divide that number by the number of readings you took and that will give you the actual tempature. Within 5 degrees is great but anything over 10 degrees can affect your cooking. This will give you an idea if your oven is out of calibration or not.
There is a calibration procedure. The instuctions are located in the owners manual and can be found here http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-85131.PDF
Just go to the "Thermostat Adjustment" section for the proper calibration procedure.
Jul 04, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
2001 pontiac aztec, temp guage shows (very) high) temp reading. I take the battery cable off, replace cable, then it appears normal. I have done this for 4 months, everything is OK. Now it no longer solves...
if you have high miles, 75k or more I would go ahead and have tempature sensor and thermostat it self change. I don't see battery cable would have any bearing to the temperature guage or cooling process. Both switch work almost the same, at time it work well other time it read or work incorrectly because it a sign of unit becoming faulty. If the temperature sensor is faulty half of the time it well give you incorrect reading however if the temp sensor working properly and the Thermostat is not, you will also get a high temp reading due to the Thermostat is not working properly allowing the hot antifreeze to flow out from the engine to the radiator which cause the hot antifreeze to be remain lock up in the engine block. Thermostat suppose to open and close when it reach its temperature; at the same time I would also replace thermostat switch which operate the cooling fan. all three tend to go bad over times; replacing all three is a great ideas. Thermostat, thermostat switch and temperature sensor.
Oct 21, 2009 | 2001 Pontiac Aztek
Fan keeps running
freezer fan runs when freezer calls for cooling
ref fan runs when fridge calls for cooling
condenser fan up top runs with compressor
lower unit condensate fan runs with compressor
fans should not be noisy
control monitors temp and will give alarm if temp rise
please contact viking as your fridge may have a safety recall on door hinges
Jul 03, 2008 | Viking VCSB483 Side by Side Refrigerator
Samsung RB2155SH Bottom Freezer Refrigerator Logo
66 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Paul
Gerry Harvey
Gerry Harvey
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
