SOURCE: Icemaker doesn't work - no ice ejected
Krakus, there is no fuse in the dispenser assy., but there are two switches mounted on the control bracket. The posts on the brackets that hold the switches are really thin and it's possible that it broke. Therefore when you are pressing the lever you are not making the switch and sending the juice to the auger motor. Remove the dispenser cover by inserting a flat blade screw driver in the slots at the bottom. Pry out gently and the cover should pop off. Then slide it up and off. Now you will be looking at the control bracket and see the switches on the left and right side. See if the switch holder is broken. If this is the case your part number is 2183771. Not a hard job, just have to take your time. Im assuming that when you tested the auger motor you verified that the drive coupler was not broke. Catriver..post back
SOURCE: Icemaker noise and malfunction
on the back wall just above or under the fill tube youl find the wire harness , simply unplug the ice maker, while your at it 3 1/4 screws mount the ice maker to the side wall, youll have more room in freezer by removing it
SOURCE: Icemaker problem crushed only not cubes
I looked at the plastic piece the solenoid was moving (from Guest's comment 03/07/08). Pushed the plastic piece up (had to push pretty hard) and it reset the solenoid to its' start/beginning position(-?) Plastic piece came back to lower position - was free to move up and down. The solenoid is working now (hear the loud clicking and see it pulling the plastic piece up) to get cubed ice, instead of putting it thru the crusher.
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Amana SXD22S2W
refrigerators are made by Whirlpool and what you have happening is common with a
couple possibilities. Most likely the W10245167 Water Inlet Valve
is not shutting off after the fill time of about 7.5 seconds. If this is
happening the water will slowly fill the
ice maker tray above the lever that it should and causes the ice to connect together
on the top thus not allowing the cubes to be harvested because they are
basically welded together as a whole piece. And the other possibility is the
ice maker itself is needing an adjustment of the water flow time. Below I will
post a Icemaker
Repair video telling how to adjust the
time and other things to look for. This is possible but most times not always the case. Adjusting the flow time is
delicate and a little change can cause too much or not enough water. Lets watch
the icemaker a little closer and see if there is ice freezing up in the fill
tube behind the ice maker. You have seen the leaky faucets before and an old W10245167 Water Inlet Valve
can do just that making a mess inside your freezer and ice maker if
leaking. Here is a Whirlpool Ice Maker
Troubleshooting PDF You can find this info on this page HERE You will need Adobe Acrobat
Reader to view these documents. The Adobe Acrobat Reader is available as a free download. I will be here should
you have any questions, Thanks Sea Breeze
D7824706Q Ice Maker Assembly
